Posted: Wed Jan 25, 2012 12:14 pm |
there is a pug garage about 45 mins from ma house so ill take it there if they cant sort it
Posted: Wed Jan 25, 2012 12:26 pm |
The Best thing to do is take it to a Pug garage,I would say that the garage who worked on yours didn't work it right,because a timing belt job would take about 3-4 hours of labor,so since your car been there since 19th!!! well it's not a rocket,to have 5 days to get it done.
Losing power means that the timing is not right,engine is not working on it's full capacity,maybe they knocked the crankshaft sensor that measure the speed of the engine while they worked on the timing belt,I hope they used genuien parts for your car,and not the after market ones.
Posted: Wed Jan 25, 2012 1:09 pm |
guarentee you they will have not used the correct tools and timing is out
if it ran fine when it went in its something they have done therefore its up to them to sort it out
Posted: Wed Jan 25, 2012 1:16 pm |
Happened to mind, it was just one tooth out on the exhaust cam. Easy mistake to make because there is two locking pin holes.
Posted: Wed Jan 25, 2012 1:26 pm |
Cheers for all the advice, im goin to mention the exhaust cam to them and see wot they say . if they dont sort it ill defo be taking it to pug.
