Online Now [95]:
Visitors: 94
Today: 822
Total: 139009836
Forums › The Car › 206 Problems › Diameter of large CV boot clip/strap
gazza82
PostPosted: Wed Jan 25, 2012 3:13 pm Up
Anyone know what the diameter of the larger cv boot strap is??? Ones loose and it's the type that can't be retightened. Grease is starting to seep out of the side.
It's for the 206CC but my guess is they are pretty much all the same size (I stand to be corrected!)
TIA!
PostPosted: Wed Jan 25, 2012 3:39 pm Up
just use the metal cable tie
ryanovsalford
PostPosted: Wed Jan 25, 2012 4:01 pm Up
I used a large jubele clip or how ever its spelt bin there for a year and not moved an inch just dont over tighten it or will just split the boot
marrygold75
PostPosted: Fri Jan 27, 2012 3:54 pm Up
plastic zip tie everytime no probs metal ones cut in the rubber
have a nice day
PostPosted: Fri Jan 27, 2012 5:37 pm Up
Just wrap a piece of string around it and that's the minimum length of tie/clip that you need
marrygold75
PostPosted: Sat Jan 28, 2012 4:27 am Up
so how many balls of string would it take to reach the moon
have a nice day
