Posted: Wed Jan 25, 2012 1:31 pm |
I need to repair the clock lights in the centre console, i've tried soldering the pins back on the board but to be honest it ain't going to happen, so i've decided the best course of action is to take a feed from the 4 bulbs and run it too a live bulb feed else where in the dash.
Does anyone know the best place to pick a feed up from ? I'm assuming the lights in the dash/ventilation panel would be best, but has any got a clue as to which wire.
Steve
| 206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out | |
Posted: Wed Jan 25, 2012 1:45 pm |
I don't recommend doing that,because you may have a short circuit,replacing the clock would be the best choice if I were you.
Posted: Wed Jan 25, 2012 3:49 pm |
What display you got? If ppt-20 I'm selling mine for £7.50 including delivery if interested.
Posted: Wed Jan 25, 2012 3:57 pm |
PPT-30 multiine MFD
Posted: Wed Jan 25, 2012 4:45 pm |
Lee wrote: |
PPT-30 multiine MFD |
Yep, it's one of those I might leave it without the display, I'm going to change the radio so I guess it's only use will be the time and temp
Posted: Thu Jan 26, 2012 7:46 pm |
What's difference between 2 clocks?
Posted: Fri Jan 27, 2012 12:25 am |
Posted: Fri Jan 27, 2012 3:32 am |
Interesting, so on my gti 2001 non plex, will fitting a better clock give me more features?
What are the benefits of changing?
Ta
