Online Now [507]:
Visitors: 506
Today: 109736
Total: 105551685
Forums › The Car › 206 Talk › Angel Eyes Dilema
Angel Eyes Dilema
danlouiee
PostPosted: Thu Jan 26, 2012 4:14 pm Up
Hello,
i have had an offer off someone on here to make my uprate my angels halos so i can wire them to a ignition live feed so they are always on.
I was wondering if anyone can recomend me some uprated bulbs before i spend out on modifying my angels? ive been told that Philips extreme Vision 100% are supposed to be good, are these any good in Angels? if not would a HID kit work in these because there is a sticker that says no HID kits, is that because of the plastic? and would they self adjust if i installed them?
all your help would be brilliant! Thanks
PostPosted: Thu Jan 26, 2012 4:25 pm Up
HIDs would work
Mrs_Howey
PostPosted: Thu Jan 26, 2012 4:38 pm Up
The halfords ultra brillance bulbs are good, on buy one get one free at the mo as well Smile
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
danlouiee
PostPosted: Thu Jan 26, 2012 5:48 pm Up
I've read reviews for the H1 bulbs and they say they aren't any different!:/ would the HID's be able to be adjusted properly like a normal bulb on the adjusters?
danlouiee
PostPosted: Thu Jan 26, 2012 5:50 pm Up
danlouiee
PostPosted: Fri Jan 27, 2012 5:04 pm Up
If I got HID's for my Angels would they still adjust up and down left and right etc and pass MOT?
If not what other bulbs is everybody using as I know the light output for these is awful!
PostPosted: Fri Jan 27, 2012 5:12 pm Up
I found my angels better than crystals and frosted.
HIDs will still adjust, and it will depend on how well you get on with the MOT'er...or how good he is.
danlouiee
PostPosted: Fri Jan 27, 2012 5:24 pm Up
If they adjust though up and down it won't be a fail will it? I have sonar angels, should I look at like ultra or something like that?
Did you really that's interesting! What bulbs did you have in your Angels?
PostPosted: Fri Jan 27, 2012 5:31 pm Up
HID's need washer jets and self leveling suspension/lamps
Ultra and In.Pro are the better makes, Sonar aren't too bad
I had Philips X-treme
kurosagi01
PostPosted: Fri Jan 27, 2012 6:32 pm Up
How did you adjust the beam up and down?? I asked someone this before,do you adjust them by a screw that's next to the main beam bulb?
danlouiee
PostPosted: Sat Jan 28, 2012 2:07 am Up
So don't do HID's because I need all that washer jet rubbish!
Are they the ultra vision extreme ones? What make angels did you have?
So your angels have adjusters you has to fit when installing them? Near the side light? That screw is the left and right adjuster, the block one next to the sidelight is an up and down one you control from inside but can be adjusted under the bonnet too!
PostPosted: Sat Jan 28, 2012 2:16 am Up
Philips x-treme +100%
Ultra
I just fitted my electric adjusters
kurosagi01
PostPosted: Sat Jan 28, 2012 3:55 am Up
unfortunately mine didn't come with the electronic adjuster and they need be adjusted manually under the bonnet i just want know what screw does what but thanks for pointing them out for me dan.
danlouiee
PostPosted: Sat Jan 28, 2012 5:14 am Up
Okay mate, I will look at getting some of those bulbs and seeing if it makes a difference, hopefully it does!
If it does I'm going to send my angels away for the LED's to be uprated!!!!:)
That's fine, what make are your angels kurosagi01?
kurosagi01
PostPosted: Sat Jan 28, 2012 7:40 am Up
I'm not entirely sure as i bought them off someone on ebay where can i check the manufacture on the angels?
Might be "lumenauto" i just typed in RSD-102102 A into google and it came up with lumenauto.
I've just ordered some 501 SMD for my sidelights and Phillips xtreme power for my angels as my xtremevision 100% dieing already.
I am also having problems with electrical problem,if i plug in my h7 into converter the full beam works but the main beam does,this only happens on my driverside. But the other side works,it didn't have this problem with my old bulbs but ever since i changed them to the phillips 100% it won't work.
However the passenger side works fine.
