Online Now [141]:
Visitors: 140
Today: 47274
Total: 138726253
Forums › The Car › 206 Problems › my engine management light just came on
frankaai
PostPosted: Sat Jan 28, 2012 6:07 am Up
my engine management light just came on only bought the car on thursday and the guy isnt answering the phone, typical, my dad owns a garage il have to get him the plug the computer into it, where does it plug in? it seems to have lost power and there is a bit of a rattle from the engine, its a 2.0 2002, has anyone had the same problem? any advice would be great, cheers
PostPosted: Sat Jan 28, 2012 6:12 am Up
You're p**sing in the wind until you have had the codes read.
Plug - Drivers side fusebox, in the cab. (Under the Steering wheel.)
frankaai
PostPosted: Sat Jan 28, 2012 6:15 am Up
i know, cheers thanks ill repost when i find out the problem, ill be taking this guy to the small claims court anyway!! f&&ker
PostPosted: Sat Jan 28, 2012 6:17 am Up
Is it a GTi or HDi? (there are 2x 2.0l engines)
frankaai
PostPosted: Sat Jan 28, 2012 6:26 am Up
its an hdi
PostPosted: Sat Jan 28, 2012 6:29 am Up
The rattle could be something or nothing.
Is the engine cover secured with four peugeot clips?
frankaai
PostPosted: Sat Jan 28, 2012 6:39 am Up
im actually not to sure im in work at the min il have to check it when i finish
frankaai
PostPosted: Sat Jan 28, 2012 9:36 am Up
got the fault codes po101 po401 and po100 said exhaust gas recirculation and mass or volume air flow, any ideas mate?
PostPosted: Sat Jan 28, 2012 9:59 am Up
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
One of the Lee's will help when they see this, they are the 'Whiz-Kids' on 206's.
My guess would be a dead MAF sensor, and a blocked/closed EGR valve. However, don't hold me on that, wait for someone to give you a more detailed answer.
Ghosty
PostPosted: Sat Jan 28, 2012 11:04 am Up
the egr may had even been disconnected, as i did it on my old D-Turbo, supposed to give you a few horses more, personally i didnt feel the difference so i reconnected it again, before i sold it.
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
PostPosted: Sat Jan 28, 2012 11:26 am Up
Already answered this in PM.
Check if the codes come back, if they do, then it'll need a new MAF. Go for genuine not China specials.
frankaai
PostPosted: Tue Jan 31, 2012 12:13 pm Up
thanks alot guys im going to reset the codes later and see what comes up again when i drive it up the motorway, will let you know, thanks again
