Latest: jackrox1992
Overall: 17186
Online Now [962]:
Visitors: 961
Today: 83142
Total: 148846941
Forums › The Car › 206 Problems › Fuel light on???
Fuel light on???
deks
PostPosted: Sat Jan 28, 2012 6:57 am Up
I have a 2001 Y plate gti the fuel level warning light is on even though it has fuel in it gauge is redaing 1/4 and i put a gallon it to be sure yet still the low fuel ight is on
is there a known fault I should be looking for specifically
thanks in advance
PostPosted: Sat Jan 28, 2012 7:09 am Up
Try filling the tank to the brim & seeing of the light goes out / fuel gauge shows the true level.
deks
PostPosted: Sat Jan 28, 2012 7:10 am Up
Yes thought I might have to try that, thanks for reply
m4tth3w
PostPosted: Sat Jan 28, 2012 7:15 am Up
My gti yellow light comes on half way between quarter and empty mark.
Don't know if this works but if you manually move the needle up a notch will the yellow light come on later?
Obviously check that it's reading right first.
PostPosted: Sat Jan 28, 2012 7:31 am Up
Needs BSI updating
fatboyslim
PostPosted: Sat Jan 28, 2012 7:47 am Up
My CC does the same and the display tells me I've got around 60 miles left
Not that it matters as I always put petrol in it when the light comes on
Yes I own a CC and I'm neither gay or a hairdresser!!
deks
PostPosted: Sat Jan 28, 2012 10:50 am Up
Lee wrote:
Needs BSI updating
thanks, I'll get that looked at
Ghosty
PostPosted: Sat Jan 28, 2012 10:53 am Up
My HDi GTi usually comes on at around 50 miles,
this has been pointed out before (by MR_BSI i think) that the light comes on when there is 1 gallon left in the tank, this seem accurate on mine as a quick check on my average MPG (says 45 mpg) then my total miles left is 45, which all seems to tally that it is working correctly. i have yet to push it to see the miles remaining to 0, or --- as it says in the manual.
as for the op's problem i would say there is a fault somewhere, as it should not be on if there is over 1 gallon in the tank.
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
PostPosted: Sat Jan 28, 2012 11:00 am Up
It needs the BSI updating, common bug in the software. And it was me who said there was a gallon left.
Ghosty
PostPosted: Sat Jan 28, 2012 11:08 am Up
sorry lee, my bad, consider my wrists slapped lol
PostPosted: Sat Jan 28, 2012 11:26 am Up
Good boy Razz lol
deks
PostPosted: Tue Feb 21, 2012 2:27 pm Up
little update seems it was mega low on fuel as it ran out last week put 2 gallons in problem solved
how silly do I feel. although I would say the gauge still isnt reading that accurately but it will do for now
thanks for the advice on this
PostPosted: Tue Feb 21, 2012 3:46 pm Up
always running low on fuel=killing the fuel pump
deks
PostPosted: Tue Feb 21, 2012 4:33 pm Up
I know, I put a gallon in the car the day it was delivered and asked the question above as light was still on afterwards, and as explained turns out it was delivered with fumes in it.
I personally never run my own cars with less than a 1/4 of a tank
PostPosted: Tue Feb 21, 2012 8:02 pm Up
I think the phrase is; 'beat this'.
