Latest: Puggingalong
Overall: 17129
Online Now [112]:
Visitors: 111
Today: 60042
Total: 101417057
Forums › The Car › 206 Problems › gear box
gear box
marrygold75
PostPosted: Sat Jan 28, 2012 3:45 pm Up
my second gear can be a bit snatchy sometimes ,could changing the gear oil make it better.its a 206 1.1
if so what oil could i use
thanks.or maybe adjusting the link rods.
have a nice day
PostPosted: Sat Jan 28, 2012 3:47 pm Up
www.aepdirect.com/tota...ry_id=5744
Cheaper from Peugeot, but cba to search. Do your own leg work
marrygold75
PostPosted: Sun Jan 29, 2012 2:43 am Up
I was thinking of useing castol syntrax would this be better.
have a nice day
PostPosted: Sun Jan 29, 2012 4:11 am Up
If you aren't going to listen, then why ask?
PostPosted: Sun Jan 29, 2012 6:44 am Up
only use 75w/80
no matter what brand. only use 75w80, if you want fancy stuff get miller or Motul, they are less than a tenner for 1 litre.
not other like 75w/90; 70w/75, 75w/140 etc.....
the PSA synchro is just picky on oil
PostPosted: Sun Jan 29, 2012 6:47 am Up
Correct oil is less then £8 for 2 litres from any Peugeot / Citroen main dealer.
Not that anyone bothers to take any notice anymore Rolling Eyes
PostPosted: Sun Jan 29, 2012 6:48 am Up
we should blame halford as they only got 75w90 oil in stock Laughing
PostPosted: Sun Jan 29, 2012 6:50 am Up
I've got 200 litres of gearbox oil in stock at work, i've no idea what spec it is, ill have a look at the barrel tomorrow Laughing
PostPosted: Sun Jan 29, 2012 6:51 am Up
i just love to nick stuff at work Sad Sad
i think i have enter the wrong section...
PostPosted: Sun Jan 29, 2012 6:52 am Up
Halfords do a 75/80 gearbox oil.
PostPosted: Sun Jan 29, 2012 6:53 am Up
I've already got enough oil borrowed from old job to keep the 206 in oil changes for a good few years yet Laughing
As for gearbox oil, that can wait till clutch change time.
PostPosted: Sun Jan 29, 2012 6:55 am Up
halford own brand?
never check their own brand oil.
PostPosted: Sun Jan 29, 2012 7:00 am Up
Yes it's Halfords own which is perfectly adequate.
PostPosted: Sun Jan 29, 2012 7:02 am Up
I'd much rather pay £7.88 at any Peugeot / Citroen main dealer for 2 litres.
