Online Now [219]:
Visitors: 218
Today: 50373
Total: 142093835
Forums › The Car › 206 Problems › 206cc wiper fuse 17 keeps blowing
wazac
PostPosted: Sun Jan 29, 2012 5:09 am Up
Hi everyone hope you can help i have a 206cc and the fuse 17 under bonnet keeps blowing have change wiper motor still the same,replace fuse and as soon as you turn ignition on it blows,i have tried it with the stalks disconnected and the mtr disconnected and still the same,any help please,thanks
i would love to reset my bsi with a hammer
brad-morris
PostPosted: Sun Jan 29, 2012 5:15 am Up
Check the wiring might be a loose wire
Check the wiring.
wazac
PostPosted: Sun Jan 29, 2012 7:14 am Up
also found if you leave ignition on you can replace fuse without blowing then turn key off then on fuse blows without touching wiper stalk
PostPosted: Sun Jan 29, 2012 7:35 am Up
Very dangerous
macj
PostPosted: Sun Jan 29, 2012 7:39 am Up
Lee wrote:
Very dangerous
I cant tell him to fit a bent nail then Shocked
PostPosted: Sun Jan 29, 2012 7:45 am Up
macj wrote:
Lee wrote:
Very dangerous
I've seen someone use a nail as the supply fuse for there amp, fire brigade wasnt very happy Rolling On The Floor Laughing
parkesie
PostPosted: Sun Jan 29, 2012 10:27 am Up
check wiring hasnt been pinched or cut when fitting new motor, also check/swap wiper relay.
disconnect motor still blows its not the motor
disconnect relay, still blow its not the relay or wiring after it.
if it doent blow its the relay or wiring from it to the motor.
if not relay or motor disconnect stalk etc
do it in a methodical way and you will find the short.
Alternatively just dont drive in the rain.
Laughing
Signature p**s
PostPosted: Sun Jan 29, 2012 10:46 am Up
Laughing
Good luck disconnecting the relay without a soldering iron Laughing
parkesie
PostPosted: Sun Jan 29, 2012 10:59 am Up
no idea where the relay on a 206 is hiding. just a generic way of finding a short. disconnect circuit at every joint or component until fuse dosnt blow.
Signature p**s
macj
PostPosted: Sun Jan 29, 2012 11:33 am Up
does the fuse just do the front motor....... or does it do other things like washers, rear wipers??
I dont know because I havent got the standard loom and fuse box any more
PostPosted: Sun Jan 29, 2012 11:47 am Up
Just does the wiper motor, 30A according to Haynes
