Latest: S2cgm
Overall: 17178
Online Now [141]:
Visitors: 140
Today: 10822
Total: 137280517
Forums › The Car › 206 Problems › Which Axle do I need??
ej2_sir
PostPosted: Sun Jan 29, 2012 2:37 pm Up
Hi,
New to this forum. Just bought myself a 206hdi d turbo as a run around and unfortunatly the seller wasnt too honest about the faults the car has! Anyway the axle bearings have collapsed on drivers side and being new to Pugs/Axles, I am a bit unsure as to what axle i need. Its rear drum with Abs. Can I fit any axle of say a 1.1 and swap my hubs or do I need to find a d turbo one? Any help would be appreciated and sorry if this has been covered, did search but couldnt find an answer
2002 206 2.0hdi
PostPosted: Sun Jan 29, 2012 2:48 pm Up
You will need a multiplex axle (2001 onwards but check to be sure) if you require the abs to work.
If your car has drum brakes then it's best and cheaper to get that, if not a disc one it should be. You can get a disc one even if you have drums already but they are more exensive and require a longer handbrake cable.
PostPosted: Sun Jan 29, 2012 2:50 pm Up
Non working / removed ABS = instant MOT failure.
PostPosted: Sun Jan 29, 2012 2:54 pm Up
I meant if it came with abs as standard, as you can simply not use the sensors if not Wink
No idea what diesels come with
PostPosted: Sun Jan 29, 2012 2:55 pm Up
OP already said in the first post the car has ABS fitted.
PostPosted: Sun Jan 29, 2012 2:58 pm Up
Bedtime Rolling On The Floor Laughing
ej2_sir
PostPosted: Sun Jan 29, 2012 4:41 pm Up
Thanks for replies. Are the drum sizes/arbs etc differnt sizes? Guess what im trying to say is am I going to have to find a beam that has been removed from a 2.0 hdi D Turbo? Or will any drum beam with abs do?
2002 206 2.0hdi
PostPosted: Sun Jan 29, 2012 4:45 pm Up
Any drum with ABS will be fine, as long as it is multiplexxed
ej2_sir
PostPosted: Sun Jan 29, 2012 4:54 pm Up
Thanks mate, I think its finally sinking in. Just got to find one now..... Give me Mcphearsons any day!!!
2002 206 2.0hdi
PostPosted: Sun Jan 29, 2012 5:05 pm Up
Don't forget you can get either bosch or lucas drums Wink
Lecktorious
PostPosted: Sun Jan 29, 2012 5:41 pm Up
Trade Rating: +59
Really? Wouldn't feel confident with a skinny ARB and TB's from a 1.1 axle going into a corner.
'98 Nile Blue 306 GTi 6
PostPosted: Sun Jan 29, 2012 5:54 pm Up
The 1.1s and 2l HDIs have the same size bars.
ej2_sir
PostPosted: Mon Jan 30, 2012 2:22 am Up
God this is a nightmare!!!!!! If I bought one that has say Lucas drums and mine are Bosch, can I change/modify the hubs or back plates to swap over?
2002 206 2.0hdi
PostPosted: Mon Jan 30, 2012 1:29 pm Up
If you are getting a new beam, does it matter? Just use the brakes that come with it.
rick-gti
PostPosted: Mon Jan 30, 2012 1:41 pm Up
Have a disc rear beam with abs from a 2000 gti with no play in the arms. if thats any good to you mate. Want £150
clio 197sport owner
