Online Now [348]:
Visitors: 347
Today: 187828
Total: 106524988
Forums › The Car › 206 Problems › Removing Mirror Glass?
james180
PostPosted: Mon Jan 30, 2012 9:04 am Up
Im trying to remove mirror so i can get to the temp sensor but not sure what is holding it on? Tried to get a screwdriver behind it but dont want to break anything?
Is there a knack to it or id it just get a bit rough with it?
Understeer is a crime.
ukskater01
PostPosted: Mon Jan 30, 2012 9:20 am Up
Don't get rough with it! Try and heat it up first to stop it cracking with a hairdryer.
I use a small pick set at work, the best one I use has a hook at the end.
james180
PostPosted: Mon Jan 30, 2012 10:58 am Up
Got it off but couldnt see anything wrong with the wires to the outside temp sender?
Better follow the wires back to see if there is a break somewhere because i know its not 39 degrees today. Laughing
brad-morris
PostPosted: Mon Jan 30, 2012 12:06 pm Up
Couldn't the sensor be f"cked not the wiring?
PostPosted: Mon Jan 30, 2012 12:14 pm Up
Point the mirror down and towards the car, then you can easily flick off the retaining pins...piece of p**s
The ballache is putting it back on.
james180
PostPosted: Mon Jan 30, 2012 12:51 pm Up
Could be the sensor,are they expensive?
