Online Now [311]:
Visitors: 310
Today: 80496
Total: 142224625
Forums › The Car › 206 Problems › 206 1.6 8v 1999 roland garros electic faultts Help!!!
blakey1976
PostPosted: Mon Jan 30, 2012 1:11 pm Up
i'm at the end of my teather with my 206 :-/ i baught her as a problem child not running soon discovered a perished earth witch i replaced and got running again but indicators dont work (hazzards do)and the front windows only work if the wipers are on. so instantly thought stalks so swapped them both over no change at all so had a sparky out who suspected the bsi unit so i changed the bsi ecu and transponder this morning and low and behold no change at all have you came across this before? its a 1999 1.6 8v roland garros . id appriciate any help you could suggest thankyou Neil
206 virgin
PostPosted: Mon Jan 30, 2012 3:13 pm Up
have you got it scanned for errors?
MrZiggerz
PostPosted: Mon Jan 30, 2012 3:28 pm Up
New ECU is drastic measures.
This.
