Posted: Tue Jan 31, 2012 6:14 am |
Does anyone no the size of the torx bolts holding the airbag to the steering wheel?
I need to no so i can get the right torx bit from work.
| | ![](images/spacer.gif) |
Posted: Tue Jan 31, 2012 6:16 am |
Trade Rating: +36
T20 I think.
Posted: Tue Jan 31, 2012 6:18 am |
rick-gti wrote: |
Steering wheel bolt is also a Torx so either borrow the set from work or go buy some from Halfords etc.
Posted: Tue Jan 31, 2012 6:21 am |
MrBSI wrote: |
rick-gti wrote: |
Steering wheel bolt is also a Torx so either borrow the set from work or go buy some from Halfords etc. |
havent got my set, i have a set to fit my ratchet but they wont fit into the hole.
i'll just get a few differnt sizes from work.
Posted: Tue Jan 31, 2012 8:12 am |
I don't think that you need torx to take the airbag off,you have to push the lock hold it from the back,and don't forget to DISCONNECT the battery while you work on Airbags.
Posted: Wed Feb 01, 2012 2:56 am |
Timon2210 wrote: |
I don't think that you need torx to take the airbag off,you have to push the lock hold it from the back,and don't forget to DISCONNECT the battery while you work on Airbags. |
OP has a NON plexed 206.
Airbag is secured with 2 x torx screws on these.
Posted: Wed Feb 01, 2012 1:19 pm |
MrBSI wrote: |
Timon2210 wrote: |
Airbag is secured with 2 x torx screws on these. |
I see :),thank you for telling me ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Wed Feb 01, 2012 1:29 pm |
It's T30
Posted: Wed Feb 01, 2012 1:31 pm |
Don't break it ![Smile Smile](images/smiles/icon_smile.gif)
| 206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out | |
Posted: Thu Feb 02, 2012 8:44 am |
Got it off in the end T30 it was.
