Latest: tebas93089
Overall: 17179
Online Now [268]:
Visitors: 268
Today: 44560
Total: 137816325
Forums › The Car › 206 Problems › Peugeot 206 problem
Peugeot 206 problem
206john178
PostPosted: Tue Jan 31, 2012 6:04 pm Up
Plugged a code reader in today and it said my car ignition coil was not working so i fitted a new coil pack and plugs engine stopped misfiring and exhaust didnt sound like it was blowing went quiet then 5 mins later same problem drove it for 10 mins and went it went past 3000 revs power kicked in then at 4000 rpm engine management light came on spark plug 4 and 1 are black and sooted carbon and 2 and 3 seem ok any 1 know what it could be Sad
John.
lmilligan
PostPosted: Tue Jan 31, 2012 6:12 pm Up
Are you using the right spark plugs? Seen many times on here that NGK plugs can cause problems on the pug petrol engines.
Martind
PostPosted: Wed Feb 01, 2012 4:01 am Up
Maybe its your cat is blocked? Maybe?!
leigh_boy
PostPosted: Wed Feb 01, 2012 4:12 am Up
i had the same problem and it was because i had bad spark plugs , even more so unlucky my brand new bosh plugs wer bad aswell bought some champion plugs from pug and was fine Smile
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
206john178
PostPosted: Wed Feb 01, 2012 6:00 am Up
its as bosh plugs
John.
lmilligan
PostPosted: Wed Feb 01, 2012 6:20 am Up
Plug in your code reader of the light has come on again like you said it has.
206john178
PostPosted: Thu Feb 02, 2012 1:37 pm Up
plugged a code reader in and it says its 2 injectors what are not working
John.
206john178
PostPosted: Fri Feb 03, 2012 7:44 am Up
bump
John.
Big_Rich180
PostPosted: Fri Feb 03, 2012 8:03 am Up
Maybe the 2 injectors arnt working.
Take it to a garage.
