Latest: lio94
Overall: 17181
Online Now [68]:
Visitors: 68
Today: 56335
Total: 141245588
Forums › The Car › Solved 206 Problems › Fuel gauge jumped.. [SOLVED]
PostPosted: Wed Feb 01, 2012 4:20 am Up
Filled-up completely a few days ago, gauge at max.
This morning it was at 3/4 mark having used some in the past days.
Now it's jumped back to full mark without putting more in.
The needle seems to be free to move up and down and settles below zero when engine is switched-off.
Damn it.
EDIT: Battery has had it. Goood pugy.
leigh_boy
PostPosted: Wed Feb 01, 2012 5:11 am Up
bad sender unit or poor earth sender units go quite often and are par of the fuel pump , easy to change but you need a drill to remove the cover
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Wed Feb 01, 2012 5:46 am Up
leigh_boy wrote:
bad sender unit or poor earth sender units go quite often and are par of the fuel pump , easy to change but you need a dripp to remove the cover
There's no rivets and steel plate on mine.
Pump is an arm and a leg for 2001 year 206.
Might try and repair it if the problem persists.
PostPosted: Sat Feb 04, 2012 5:58 am Up
Solved.
Battery.
bezford
PostPosted: Tue Apr 24, 2012 1:29 pm Up
my 2002gti starts fine but im gettin this s**t with the fuel gauge?how did you finaly conclude the battery was to blame?and not a dodgy sender on the pump?
R.HYDE
PostPosted: Sat May 19, 2012 7:18 am Up
The very same day the starter wouldn't crank due to flat battery.
Replaced battery and problem dissapeared and has never come-back (see date in post).
