Online Now [207]:
Visitors: 206
Today: 24692
Total: 143014796
Forums › The Car › 206 Talk › 206 steering arm joint turning
danuk76
PostPosted: Wed Feb 01, 2012 4:14 pm Up
hi
I cannot seem to tighten the steering arm ball joitn it just keeps turning, any ideas please. its a taper fit but cant seem to tighten??
Bottom ball joint back in = drop the subframe
Dont buy cheap spring compressors, get a garage to do it with proper machine
Ste
PostPosted: Wed Feb 01, 2012 4:40 pm Up
Staff - Ste
Put a jack under the joint and jack it up a wee bit, once it has pressure on it it stops spinning and allows you to tighten the bolt Smile
The Cars:
danuk76
PostPosted: Wed Feb 01, 2012 4:49 pm Up
thanks for reply
I already tried this, will try again tommorow, just spent hours getting the the bottom ball joint in due to not knowing about dropping the subframe to get it back in.
Ste
PostPosted: Wed Feb 01, 2012 5:00 pm Up
Staff - Ste
Takes quite abit of pressure to stop it moving bud, but dont put so much on that you dont feel safe doing so if you get me?
The Cars:
parkesie
PostPosted: Thu Feb 02, 2012 12:51 am Up
Push it in start the nut then get some one to apply pressure to the steering as you turn the nut. Assuming you have both wheels on the floor should work.
Signature p**s
danuk76
PostPosted: Thu Feb 02, 2012 5:27 am Up
all done, thanks all
bit of wood on the arms threads upto the top of inner wing, then trolly jack underneath the joint to crush it together.
