Latest: tbafonso
Overall: 17130
Online Now [55]:
Visitors: 54
Today: 49785
Total: 102521993
Forums › The Car › 206 Problems › White stuff on underside of oil cap...
L5_UKS
PostPosted: Thu Feb 02, 2012 10:05 am Up
No not that... Rolling On The Floor Laughing
Right yesterday I went to top up the oil abit, and found on the underside there was this white substance of the cap.
It had a oil change around a month ago and it was fine then, I know the normal signs are that the head gasket has gone but surely not that quickly?
Could it just be condensation due to the cold weather?
Luke.
Big_Rich180
PostPosted: Thu Feb 02, 2012 10:06 am Up
I used to get this with the 180, its just from condensation, unless there's loads I wouldnt worry about it.
L5_UKS
PostPosted: Thu Feb 02, 2012 10:31 am Up
Yeah there wasn't much there.
Didn't think it could have been. but now can put my mind at rest Smile
Cheers Rich.
PostPosted: Thu Feb 02, 2012 11:24 am Up
It just need a couple of decent length runs to get rid of it. Wiping it will help too.
gixxerkev
PostPosted: Thu Feb 02, 2012 11:26 am Up
Is there any white stuff on the coolant expansion tank cap or in the water itself? If there is its probably the head gasket. How old is the car and how many miles has it done?
An Ex '03 1.4 GLX driver, German technology all the way now.
L5_UKS
PostPosted: Thu Feb 02, 2012 11:38 am Up
Yeah recently have only been using it for 2/3 miles a day.
Will take it on a long run on the weekend Smile
First thing i done was wipe it Wink
L5_UKS
PostPosted: Thu Feb 02, 2012 11:39 am Up
Nope coolant take is fine thats the first thing I checked after I seen it and that was all clear.
I think its just condensation as said above, fingers crossed eh?! Smile
PostPosted: Thu Feb 02, 2012 11:40 am Up
It doesn't need driving hard, it just driving long enough to vent it all out.
Fifer
PostPosted: Thu Feb 02, 2012 11:41 am Up
Wife's car had the same. Only used for short runs. Nif no oil loss or coolant loss then should be okay
1.4hdi 02
gixxerkev
PostPosted: Thu Feb 02, 2012 11:44 am Up
Yeah ok, sounds like a reasonable explanation if you've only been doing very short journeys.
L5_UKS
PostPosted: Thu Feb 02, 2012 12:06 pm Up
Yeah Smile
Cheers buddy.
