Online Now [1164]:
Visitors: 1163
Today: 227397
Total: 149293131
Forums › The Car › 206 Problems › 206 central locking
206 central locking
rick-gti
PostPosted: Thu Feb 02, 2012 9:31 am Up
Hi guys my gti has just started to unlock itself, basically when i lock it with the fob and using the key in the lock it justs unlocks straight after until it wont lock at all.
anyone got any ideas before i start dissmantling both the doors.
clio 197sport owner
pnut_man
PostPosted: Thu Feb 02, 2012 12:34 pm Up
is your boot shut properly?
rick-gti
PostPosted: Thu Feb 02, 2012 1:12 pm Up
Yes mate, it does seem like there's a door open but there's not. Have read that the regulators get wet and break down. Where are these situated?
clio 197sport owner
Rob2859
PostPosted: Thu Feb 02, 2012 1:42 pm Up
probably a solenoid has gone. Try unplugging the boot lock first too. Mine packed in but when I pulled it off it let the other doors lock. It also immobilised the car at one point until I pulled it out.
rick-gti
PostPosted: Thu Feb 02, 2012 1:56 pm Up
Will give that ago. Do you think doin a bsi reboot might work?
clio 197sport owner
Rob2859
PostPosted: Thu Feb 02, 2012 2:07 pm Up
I very much doubt it. If unplugging the boot does not work try ones for the doors. One at a time and you will know which lock it is.
rick-gti
PostPosted: Fri Feb 03, 2012 3:37 am Up
i found a loose wire on the boot catch, so will re-attach this and see if that solves my problem.
clio 197sport owner
rick-gti
PostPosted: Sat Feb 04, 2012 1:47 pm Up
Does anyone know what the connector on the boot catch is? ( the part that the boot closes onto)
clio 197sport owner
PostPosted: Sat Feb 04, 2012 1:48 pm Up
Its the sensor for the alarm / boot open warning.
