Posted: Thu Feb 02, 2012 9:37 am |
Noticed today that the coil instrument on dash doesnt come on before i try to start, should it always?
The coil is the diesel pre heat warning light.
| 206Hdi Mapped. De-cat next | |
Posted: Thu Feb 02, 2012 1:13 pm |
Glow plugs only work when its minus degrees
Posted: Thu Feb 02, 2012 2:09 pm |
Today was -4 in Chester
Posted: Thu Feb 02, 2012 2:26 pm |
only 0.5 sec preheating at that temperature
Posted: Thu Feb 02, 2012 3:30 pm |
Having just read through a project thread, could it be egr related? I had mine removed on my 306 for years no problem?
Posted: Thu Feb 02, 2012 4:37 pm |
mine was unplugged too, no problem to start this morning/ tonight where it was -5 outside.
it will take longer to warm up but it shouldn't affect starting
it takes about 4-5 sec cranking time though
Posted: Sat Feb 04, 2012 4:33 am |
Right had the battery tested again today. Does anyone know what cranking amp the hdi should have?
Bearing in mind i had driven it for about 20mins before I had it tested, at 400CA it passed, at 600 and 500 it failed. Sticker on battery isnt very clear as to what CA the battery is...
Posted: Sat Feb 04, 2012 5:01 am |
Changed the battery on the Mrs. 1.4 Hdi yesterday as at -5 C it turned over 4 times then died, £70 for new battery and al'ls sorted now. Was the same battery as yours TY-HDI, and it was probably the original.
| An Ex '03 1.4 GLX driver, German technology all the way now. | |
Posted: Sat Feb 04, 2012 5:42 am |
Ok thanks mate, think ill try a new battery and see what difference it makes.
Posted: Sat Feb 04, 2012 7:35 am |
not sure...
mine has 540CCA
Posted: Sat Feb 04, 2012 7:41 am |
Iv ordered a new one now with 640ca. If that struggles i have a problem.ha
Posted: Sat Feb 04, 2012 7:44 am |
what brand?
will be better from varta or bosch
Posted: Sat Feb 04, 2012 7:57 am |
| Seabook wrote: |
not sure...
mine has 540CCA |
My Varta has 610 CCA, starts a TU3 easily
Posted: Sat Feb 04, 2012 8:50 am |
Exide
Posted: Sat Feb 04, 2012 9:28 am |
