Latest: tbafonso
Overall: 17130
Online Now [272]:
Visitors: 271
Today: 65592
Total: 104116258
Forums › The Car › 206 Problems › 51 reg 1.4 206
51 reg 1.4 206
ste28365
PostPosted: Mon Feb 06, 2012 4:26 pm Up
lost all power on my 206 at traffic lights. car wouldnt start n went to garage. diagnosed as battery fault and also a burnt wire. car worked ok but same night while driving heard a loud 'ratchet ' like noise and lost the clutch, the pedal just went slack and couldnt get it in 2 gear. after pumping the pedal for a while got it to work but this problem occured 3 more times. also now when i turn off the engine get a whirring sound from the ecu. had it back to garage and mechanic checked all the clutch but cant find a problem and car seems ok now but i am a bit dubious. auto electrician also said that noise from the ecu is common and hes had it before but it will be ok. any advice greatly appreciated
dont know what im doing
Matt
PostPosted: Mon Feb 06, 2012 4:31 pm Up
Trade Rating: +32
The Mysterious "Cut Out" problem strikes again?
