Online Now [1016]:
Visitors: 1015
Today: 149055
Total: 148909528
Forums › The Car › 206 Problems › my 206 gti problem
my 206 gti problem
johnuk
PostPosted: Mon Feb 06, 2012 9:59 am Up
my are is gti 139bhp its a x reg plate
i last used my car on friday all fine then its snow lol, and tried useing it today day and it will not start,
the engine is turning,but not starting
just thinking want could do this i,e the plug are not getting a spark( i will check later tonight when i my gets back as he has the tools to check)
i just would like to see if anyone has had this probably
my gti problem
lmilligan
PostPosted: Mon Feb 06, 2012 10:13 am Up
Battery?
Big_Rich180
PostPosted: Mon Feb 06, 2012 10:15 am Up
lmilligan wrote:
Battery?
Would the engine not turn if the battery was dead?
johnuk
PostPosted: Mon Feb 06, 2012 10:25 am Up
battery is only a year old,
and the car is in good condition ive had it for 6 year now
i will take it done the garage if i can not get it done myself, i will be checking the plugs later to see if there getting a spark
just annoying it happin when it snowing lol
my gti problem
PostPosted: Mon Feb 06, 2012 10:38 am Up
Check crank sensor, double relay, transponder aerial.
johnuk
PostPosted: Mon Feb 06, 2012 10:42 am Up
ok will look in to them,
my gti problem
PostPosted: Mon Feb 06, 2012 10:44 am Up
Also remember the 206 immobiliser DOESN'T stop the starter motor from working Wink
PostPosted: Mon Feb 06, 2012 10:49 am Up
Can you hear the fuel pump priming when the ignition is switched on?
johnuk
PostPosted: Mon Feb 06, 2012 11:00 am Up
yes i can hear the feul pump primming,
and how would you now if it the immobliser is not working correctly,
looks like a garage job to sort it out,
my gti problem
PostPosted: Mon Feb 06, 2012 11:21 am Up
Key switched OFF but in the ignition barrel.
Open the drivers door & listen for the key in ignition warning noise Wink
No noise = transponder in the key isnt being read.
johnuk
PostPosted: Mon Feb 06, 2012 11:26 am Up
the keys work just checked,
so am guess it could be one of the seniors
my gti problem
PostPosted: Mon Feb 06, 2012 1:24 pm Up
when did you change your timing belt?
johnuk
PostPosted: Mon Feb 06, 2012 1:34 pm Up
belts got done about 3 years ago,
but i think its just the spark plugs they are over do for a change, will change tomorrow
my gti problem
johnuk
PostPosted: Tue Feb 07, 2012 7:29 am Up
ALL FIXED SPARK PLUG WERE THE PROBLEM
my gti problem
PostPosted: Tue Feb 07, 2012 7:40 am Up
What plugs did you replace them with? Hope you didn't put NKG in there
