Posted: Thu Feb 09, 2012 9:09 am |
hi guys can you tell me where ecu is on my 206 14 hdi and if i disconnect it put a bit of wd40 as i may have a a problem with it and reconnect it is that ok ? thanks
Posted: Thu Feb 09, 2012 9:22 am |
Are you being serious?
Posted: Thu Feb 09, 2012 9:24 am |
no i wrote it for fun
Posted: Thu Feb 09, 2012 9:43 am |
where you from in kent?
Posted: Thu Feb 09, 2012 9:53 am |
otford ?
Posted: Thu Feb 09, 2012 10:32 am |
I doubt wd40 will fix any problem with the ecu unless its squeeking in the bracket
what problem you got we may be able to help or point you in the right dirrection to fix it without helping you knackering the ecu
| 206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955) | |
Posted: Thu Feb 09, 2012 10:35 am |
i have a moments loss of power sometimes was only gonna wiggle the plug a little and spray it ?
Posted: Thu Feb 09, 2012 10:39 am |
and just to add it happens when weather is damp and cold
Posted: Thu Feb 09, 2012 10:46 am |
I wouldn't have thought the problem your experiencing would be from your ecu. And if you did need to clean it electrical cleaner would be best. Not sure on the problem though, would be best to get any codes read
| You never really learn to swear until you learn to drive | |
Posted: Thu Feb 09, 2012 12:34 pm |
Use water
