Posted: Thu Feb 09, 2012 5:09 am |
So basicaly after my first day diving my 206 my passenger seat has decided it doesnt want to budge from the reclining position it will move to allow passengers into the back seats just wont chang its reclining position when i use the handles to move it.
Has anybody else had this problem and how did u fix it?
Posted: Thu Feb 09, 2012 5:40 am |
I seem to remember seeing that the seats run on plasic bearings and when these get worn they are unable to move, always used to just wrag the seat about a bit and it would free it up, not the correct way of doing things but it sorted it.
Posted: Thu Feb 09, 2012 10:38 am |
More than likely the pin under the sliding mechanism has dropped out, look for a metal pin about 3 cm long and 4 mm in diameter, cant remember exactly where it goes without taking the seat out which i've got to do in the next day or so so i'll take a pic when I do btw you have tried pulling the handle forwards as the seat only slides forwards when handle pulled forwards pushing handle backwards only moves top part of the seat
Posted: Thu Feb 09, 2012 7:03 pm |
Its the top part that aint movin the bottom is fine
