Online Now [381]:
Visitors: 380
Today: 122118
Total: 106316239
Forums › The Car › 206 Problems › ecu 206 14 hdi
ecu 206 14 hdi
nashy
PostPosted: Thu Feb 09, 2012 8:09 am Up
hi guys can you tell me where ecu is on my 206 14 hdi and if i disconnect it put a bit of wd40 as i may have a a problem with it and reconnect it is that ok ? thanks Laughing
nashy
lmilligan
PostPosted: Thu Feb 09, 2012 8:22 am Up
Are you being serious?
nashy
PostPosted: Thu Feb 09, 2012 8:24 am Up
no i wrote it for fun
nashy
glenpring
PostPosted: Thu Feb 09, 2012 8:43 am Up
where you from in kent?
nashy
PostPosted: Thu Feb 09, 2012 8:53 am Up
otford ?
nashy
Dutch-HDi
PostPosted: Thu Feb 09, 2012 9:32 am Up
I doubt wd40 will fix any problem with the ecu unless its squeeking in the bracket Rolling On The Floor Laughing
what problem you got we may be able to help or point you in the right dirrection to fix it without helping you knackering the ecu
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
nashy
PostPosted: Thu Feb 09, 2012 9:35 am Up
i have a moments loss of power sometimes was only gonna wiggle the plug a little and spray it ?
nashy
nashy
PostPosted: Thu Feb 09, 2012 9:39 am Up
and just to add it happens when weather is damp and cold
nashy
ukskater01
PostPosted: Thu Feb 09, 2012 9:46 am Up
I wouldn't have thought the problem your experiencing would be from your ecu. And if you did need to clean it electrical cleaner would be best. Not sure on the problem though, would be best to get any codes read
PostPosted: Thu Feb 09, 2012 11:34 am Up
Use water
