Online Now [1245]:
Visitors: 1244
Today: 76945
Total: 149152909
Forums › The Car › 206 Problems › diagram of rear abs drum set up...
heppy1
PostPosted: Thu Feb 09, 2012 2:07 pm Up
could anyone help with a diagram of rear abs set up with drums, where the sensor is located ect as think someone has changed the rear of mine and did away with it.Thanks
206xs
PostPosted: Thu Feb 09, 2012 2:17 pm Up
drumswithabs by LeeThr, on Flickr
heppy1
PostPosted: Thu Feb 09, 2012 2:26 pm Up
i cant seem to see the abs sensor in that photo and cant scroll down side bar bit to get number of it?
206xs
PostPosted: Thu Feb 09, 2012 4:15 pm Up
abs sensor is not on that page and i have already given you the number
ej2_sir
PostPosted: Thu Feb 09, 2012 4:36 pm Up
Had a quick look on mine other day as I need a new axle. Pretty sure the trailing arm has a mounting for the abs sensor, Its not part of the drum/backing plate assembly
2002 206 2.0hdi
PostPosted: Thu Feb 09, 2012 4:39 pm Up
nice to know that...
i only sure disc axle got a hole on the arm to plug the abs sensor as my drum axle has no abs Laughing Laughing Laughing
ej2_sir
PostPosted: Thu Feb 09, 2012 4:55 pm Up
lol dont think mine will for much longer as i cant find a bloody 2nd hand beam with drums an abs for love nor money!!
2002 206 2.0hdi
PostPosted: Thu Feb 09, 2012 6:16 pm Up
It also doesnt take 3 different new threads started by the same person to sort out the same problem Rolling Eyes
PostPosted: Fri Feb 10, 2012 3:45 am Up
Why not simply put a disc axle on then?
ej2_sir
PostPosted: Fri Feb 10, 2012 1:16 pm Up
Sorry for the thread hijack but with regards to the post above, Someone has offered me a disk beam with abs from a pre plex 2000 model. Could I fit this and use the multiplex wiring/abs sensors from my drum beam to make it all work? Thanks in advance and sorry again Laughing
2002 206 2.0hdi
