Posted: Fri Feb 10, 2012 1:30 pm |
So mine were crap so i went and brught a set of flat blade ones, thes didn't touch the edges of the screen so i assumed it was just the flat blade ones, i've just been out and brought a standard pair and am having the same problem any idea or do i have to go direct to peugeot and but them at £15 a side?
I'm going to take the new ones back and complain that they don't fit the windscreen and try and get my money back
| "if someone has put it together then I will take it apart" it might never work again but at least I will have an understanding of how it worked and might be able to buy another
The voices in my head may not be real, but they have some good ideas!! | |
Posted: Fri Feb 10, 2012 1:32 pm |
Sounds about right no problem with them.
What size did you get in the flat blades?
Posted: Fri Feb 10, 2012 1:55 pm |
Trade Rating: +32
For normal blades you need 22" for passenger side and 21" for drivers side.
Posted: Fri Feb 10, 2012 2:09 pm |
They were 22/22S but about an inch of the blades are not being used, i'll take them back and get a smaller one on the drivers side, but if i get a smaller size will it still clear the rain sensor?
Posted: Fri Feb 10, 2012 2:30 pm |
| Frost wrote: |
They were 22/22S but about an inch of the blades are not being used, i'll take them back and get a smaller one on the drivers side, but if i get a smaller size will it still clear the rain sensor? |
The problem your asking about is NORMAL for the 206 windscreen, there's NOTHING wrong with it, its just a quirk of the design curve of the glass.
Posted: Fri Feb 10, 2012 2:32 pm |
So it won't fail the MOT because it doesn't clear the windscreen effectivly?
Posted: Fri Feb 10, 2012 2:35 pm |
| Frost wrote: |
| So it won't fail the MOT because it doesn't clear the windscreen effectivly? |
Its only about the first 9" / 12" inches right on the end of the blades sweep on the edge of the drivers side of the screen.
Its a built in design quirk
