Latest: Stu-mill
Overall: 17131
Online Now [65]:
Visitors: 65
Today: 3283
Total: 104890948
Forums › The Car › 206 Talk › My 206, Solid Ice and a Rock Face
Go to page Previous  1, 2
L5_UKS
PostPosted: Sat Feb 04, 2012 8:35 pm Up
As above not worth the effort and money to fix that, Better scrapping and buying another Very Happy
Rob2859
Oh that has not gone well. I have bent wishbones before but never totally snapped one. They are pretty thick. Must have hit it hard.
PostPosted: Sun Feb 05, 2012 2:14 am Up
How can anybody say that's not worth repairing? Wishbones are designed to break, subframes are supposed to bend to save the body from damage. The photos don't show enough detail.
macj
PostPosted: Sun Feb 05, 2012 2:57 am Up
What He Said
I would have bought three cars by now if you never replaced a few bent parts
PostPosted: Sun Feb 05, 2012 3:23 am Up
Not real;y worth it on the value of the car though is it. Plus, who can say the damage you cant see. Its easy to replace parts you can see are broken.
PostPosted: Sun Feb 05, 2012 3:24 am Up
you are right, but not on a car that only worth GBP 650
GLX_laney
PostPosted: Sun Feb 05, 2012 3:34 am Up
It is my first, though, and it's worth more than that in my opinion. What would i be looking at repairing and how much would it cost/ Crying or Very sad
I.C.E killed my car.
PostPosted: Sun Feb 05, 2012 3:39 am Up
It's impossible to say without seeing everything.
kurosagi01
PostPosted: Sun Feb 05, 2012 4:08 am Up
Car needs a complete examination in my opinion if you want keep it,like the engine bay,suspension,centre pipes etc etc. If all those are okay then its all case of replacing the body parts and things you listed.
Apart from the things you listed that needs changing like wishbone,driveshaft.
You should be able to get the wing panel cheap from scrapyard if they have your colour and as for the side skirt maybe but i'm not entirely sure myself if that can be replaced too?? Unless someone can correct me on the side skirt.
Your probably won't be able to find front bumper like yours same colour but you will be able to get one cheap if you scout around on ebay or again check how much the scrapyard sells them.
PostPosted: Sun Feb 05, 2012 4:28 am Up
You mean the sill that is welded on.
If you know what your doing with tools it could be an easy repair BUT I wouldnt trust 90% of the people on here to actually know what there doing / make a safe repair.
Ghosty
PostPosted: Sat Feb 11, 2012 1:13 pm Up
yes the sideskirt is wielded on, so that would need a proper mechanic to cut and replace £150, i have seen lots of 206s with bent side skirts seems to be very hollow behind there
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
PostPosted: Sat Feb 11, 2012 1:21 pm Up
206 doesnt even have sideskirts.
You mean the outer sill panel, its perfectly normal for it to be hollow behind there on a car.
Page 2 of 2
