Online Now [108]:
Visitors: 107
Today: 85288
Total: 117039223
Forums › The Car › 206 Problems › problem changing gears and starting in cold
lisa206
PostPosted: Sat Feb 11, 2012 3:45 pm Up
car was fine in summer but now seems its probably due to the cold.When i start car its not steady. Revs low then normal a few times. When i'm driving and when press clutch down to change gears the car will under rev and cut out , but sometimes won't cut out will just under rev. tried coil pack and spark plugs :S
LISA 206 180
PostPosted: Sat Feb 11, 2012 3:47 pm Up
Not fitted NGK spark plugs I hope Wink
lisa206
PostPosted: Sat Feb 11, 2012 4:27 pm Up
no they were bosch spark plugs .
LISA 206 180
Taff!
PostPosted: Sat Feb 11, 2012 6:02 pm Up
MPG dropped at all? Do you have problems starting just in the morning or throughout the day? Does it start fine when warm?
206 1.6 Quiksilver
troy
PostPosted: Sat Feb 11, 2012 6:18 pm Up
try a engine coolant temp sensor on it, this will alter the fueling if faulty, theyre usually pretty cheap.
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
Taff!
PostPosted: Sat Feb 11, 2012 6:30 pm Up
My bet is that too. Just had exactly that including under revving but not cutting out when changing gears
206 1.6 Quiksilver
PostPosted: Sun Feb 12, 2012 5:40 am Up
If you have a late model 1.4i, check here too: www.206info.co.uk/Foru...39062.html
lisa206
PostPosted: Sun Feb 12, 2012 12:18 pm Up
MPG does drop when engine is cold. It splutters aswell. It starts first time every time , when its started the idle is not steady. The cars perfect when warm.
Will try a temp sensor, hopefully sorts it.
LISA 206 180
coopskin
PostPosted: Sun Feb 12, 2012 12:46 pm Up
Trade Rating: +13
clean your stepper motor
check your battery condition
check your alternator condition
lisa206
PostPosted: Mon Feb 20, 2012 4:01 pm Up
I've fitted the blue coolant temperature sensor, this hasn't changed the problem ,it still happens when the car is cold. Is there another temperature sensor?
LISA 206 180
