Posted: Sat Feb 11, 2012 3:45 pm |
car was fine in summer but now seems its probably due to the cold.When i start car its not steady. Revs low then normal a few times. When i'm driving and when press clutch down to change gears the car will under rev and cut out , but sometimes won't cut out will just under rev. tried coil pack and spark plugs :S
Posted: Sat Feb 11, 2012 3:47 pm |
Not fitted NGK spark plugs I hope
Posted: Sat Feb 11, 2012 4:27 pm |
no they were bosch spark plugs .
Posted: Sat Feb 11, 2012 6:02 pm |
MPG dropped at all? Do you have problems starting just in the morning or throughout the day? Does it start fine when warm?
Posted: Sat Feb 11, 2012 6:18 pm |
try a engine coolant temp sensor on it, this will alter the fueling if faulty, theyre usually pretty cheap.
| 2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd | |
Posted: Sat Feb 11, 2012 6:30 pm |
My bet is that too. Just had exactly that including under revving but not cutting out when changing gears
Posted: Sun Feb 12, 2012 5:40 am |
Posted: Sun Feb 12, 2012 12:18 pm |
MPG does drop when engine is cold. It splutters aswell. It starts first time every time , when its started the idle is not steady. The cars perfect when warm.
Will try a temp sensor, hopefully sorts it.
Posted: Sun Feb 12, 2012 12:46 pm |
Trade Rating: +13
clean your stepper motor
check your battery condition
check your alternator condition
Posted: Mon Feb 20, 2012 4:01 pm |
I've fitted the blue coolant temperature sensor, this hasn't changed the problem ,it still happens when the car is cold. Is there another temperature sensor?
