Latest: S2cgm
Overall: 17178
Online Now [59]:
Visitors: 56
Bots: 2
Members: 1
Today: 21642
Total: 136666870
Forums › The Car › 206 Problems › 206CC Boot Lock
206CC Boot Lock
gazza82
PostPosted: Sun Feb 12, 2012 8:06 am Up
Ours won't lock. First it wouldn't unlock, but now it opens everytime but you can't lock it.
When you hit the central locking, should there be a noise from the boot lock area? Click, buzz, etc? I hear silence.
It was too cold yesterday to start pulling the boot apart, so anyone have any ideas?
PS It's a pre-plex, 2001 model.
Thanks!
PostPosted: Sun Feb 12, 2012 8:09 am Up
Might have froze up, and needs lubing
Martind
PostPosted: Sun Feb 12, 2012 9:35 am Up
When I had mine (2001 Pre) the boot would never unlock with the Central Locking. You always had to use the key for the first time (then you could close it and open it until you pressed the button on the key to lock the doors)
I never heard any noise from the boot lock when locking or unlocking from the button on the key, only the 'buzz' when unlocking the boot itself manually.
I don't know what is causing it not to lock though, sorry.
gazza82
PostPosted: Fri Mar 16, 2012 11:31 am Up
Well. I've got the car from 24th to 31st ... so the boot lock is on the list to be investigated.
So far:
New O/S lower suspension arm (split balljoint cover)
New N/S outer CV gaiter clip (the tie-wrap some muppet fitted keeps coming off)
Swap out rear light units for phase 2s
Replace blown bulbs in upper brake light
Check out Lambda/cat fault codes with PP2000 when my cables arrive!
And possibly an MOT test ...
DRAPER
PostPosted: Fri Mar 16, 2012 12:12 pm Up
What He Said
boots only first opens when using the key
206 CC 2.0 GTI SE
HAPPY AS A PUG IN MUD
Lee wrote:
Buy a new car. The 1.9D is s**t anyway.
HA love it Smile
gazza82
PostPosted: Sun Mar 25, 2012 6:32 am Up
The end of the actuator rod on the solenoid/actuator motor is bent and as it's plastic, it's unlikely to go back straight without snapping. I could try warming it in very hot water, but I don't think it will last long.
When the central locking activates, the rod connecting the solenoid to the lock pushes through the solenoid rod and wedges in the wrong place. So when we try and lock the boot with the key, it's gets jammed up and stuck.
Going to get a new solenoid/actuator box ... for now, it's disconnected.
craigdmjv
PostPosted: Thu Apr 05, 2012 2:38 pm Up
same here i was told its normal my brothers cc is the same Rolling Eyes
Squeaker
PostPosted: Thu Apr 05, 2012 3:12 pm Up
I've got some for sale when the time is right Smile
gazza82
PostPosted: Fri Apr 06, 2012 8:20 am Up
I had a set in the garage waiting to be fitted ... Wink
