Latest: Kifi69
Overall: 17183
Online Now [1078]:
Visitors: 1077
Today: 107403
Total: 143525051
Forums › The Car › 206 Talk › Side Dependant Struts.
Squeaker
PostPosted: Sun Feb 12, 2012 4:16 pm Up
Just wondering what the differences are between the right and left strut, they look the same to me. Even the pistons look the same length.
Also what would happen or what problems would be caused by the right strut been put on the left and vice versa?
PostPosted: Sun Feb 12, 2012 4:34 pm Up
Mine aren't sided
Squeaker
PostPosted: Sun Feb 12, 2012 4:47 pm Up
Oh thought i read on here that they were.
PostPosted: Sun Feb 12, 2012 4:50 pm Up
Mine weren't either.
PostPosted: Sun Feb 12, 2012 4:54 pm Up
I thought they were sided, because of were the droplink connections are?
EdCherry
PostPosted: Sun Feb 12, 2012 4:57 pm Up
The brackets make them sided.
PostPosted: Sun Feb 12, 2012 5:00 pm Up
i use coilies so that might not be helpful Laughing
is the drop link mounting hole at the same place?
PostPosted: Sun Feb 12, 2012 5:07 pm Up
It shouldnt make a difference that your using coilovers, you still need to connect coilovers, but thinking about it, they must be the same either way there fitted.
Squeaker
PostPosted: Sun Feb 12, 2012 5:43 pm Up
So if its just the droplink mounitng spaces, what problems would be caused by putting wrong one on wrong side?
PostPosted: Sun Feb 12, 2012 5:47 pm Up
None as far as i can think. As long as they fit the hub, and everything conects ok.
PostPosted: Sun Feb 12, 2012 6:11 pm Up
the bracket for the drop link can rotate on my coilies, plus i don't run front ARB Laughing
PostPosted: Mon Feb 13, 2012 5:08 am Up
my h&r cups are sided its the mount for the arb drop links that make them sided they are slightly offset
