Posted: Mon Feb 13, 2012 5:28 am |
I don't have a trip computer, so it's always worked out from the amount of fuel I put in...
It has done 107,600 so not much at all really. I've only had the car since the end of September so it hasn't been serviced since i've had it.
I need to see about getting some reconned injectors and doing a service on it to be honest.
I did however, disconnect the intake pipe to the air box, make it shorter and poke it downwards so there is less restriction and I did my long drive and it seemed to help. Whether it was coincidence, I don't know :/
| Peugeot 206 HDI LX 2.0L (2002) | |
Posted: Mon Feb 13, 2012 8:14 am |
propaintballa wrote: |
Easy & cheap enough to retrofit on a multiplexed 206
Posted: Tue Feb 14, 2012 1:44 am |
MrBSI wrote: |
Easy & cheap enough to retrofit on a multiplexed 206  |
Someone said this to me before and is a way of telling if it's plexed or not, the amount of connectors on the back of the instrument cluster? Because mine has two...
Posted: Tue Feb 14, 2012 11:47 am |
MrBSI wrote: |
Someone said this to me before and is a way of telling if it's plexed or not, the amount of connectors on the back of the instrument cluster? Because mine has two... |
That makes it NON plexed then.
Posted: Tue Feb 14, 2012 12:44 pm |
MrBSI wrote: |
MrBSI wrote: |
That makes it NON plexed then. |
Yeh, that's what i thought...
Economy is definitely better, i've noticed it on short runs...
Still needs a service but need to get this injector ticking sorted out
