Online Now [133]:
Visitors: 132
Today: 33590
Total: 138768824
Forums › The Car › 206 Problems › Central locking not working?? Please help....
206sw
PostPosted: Thu Feb 16, 2012 4:59 pm Up
I seem to have a problem with the central locking of my 2007 Peugeot 206.
It's failing to lock one of the rear doors, which I'm guessing is doesn't to a fault solenoid/lock. But my question is is there a way to manually lock the rear door until I can get it sorted?? If I lock via central locking the rear door will remain unlocked and if used (opened), will unlock all the other doors (not good!!)
In other car you could just press the button down or push the door open lever in to do this but I can't see this as possible. Am I missing something obvious??
Thanks in advance!!!!!
PostPosted: Thu Feb 16, 2012 5:54 pm Up
Disconnect the battery. Then use your key to manually lock each door.
206sw
PostPosted: Thu Feb 16, 2012 6:03 pm Up
Sorry, but its the rear door that's the problem. Is there no way to overide and lock from the inside?
PostPosted: Thu Feb 16, 2012 6:09 pm Up
Why does that stop you disconnecting the battery and locking them manually? Is there not locks on the rear doors?
No. Sounds like the solenoid is f*cked (30min job to replace). The electric stops the rod from going down. Although tbh, one night isn't gonna make a difference regardless of where you live. If someone wants in a 206, they will get in anyway. Just get it sorted tomorrow.
206sw
PostPosted: Thu Feb 16, 2012 6:18 pm Up
I believe that on older models there are buttons on the doors that you can push down to lock the doors from the inside but mine doesn't have them....
PostPosted: Thu Feb 16, 2012 6:24 pm Up
No you can't. The electrics stop the rod from being pushed down (if you had it).
