Online Now [1254]:
Visitors: 1253
Today: 118015
Total: 149191496
Forums › The Car › 206 Problems › Boot rattle, I saw one thread...
gpvecchi
PostPosted: Thu Feb 16, 2012 3:29 pm Up
I remember that there was a thread to help solving boot rattle, but I can't find it...
Any advice, please?
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
Lecktorious
PostPosted: Thu Feb 16, 2012 3:32 pm Up
Trade Rating: +59
Any advice, please?
Wrap black insulating tape around the stricker, or replace the latch (which isn't expensive, not over here anyway).
'98 Nile Blue 306 GTi 6
rick-gti
PostPosted: Thu Feb 16, 2012 3:56 pm Up
Try moving the latch thats fitted to the car. I did this to mine and stopped it. Was driving me mad.
clio 197sport owner
Ahoward87
PostPosted: Thu Feb 16, 2012 3:58 pm Up
I done the same as rick, I just moved mine to a good position and all was good after.
If life passes you by...... Shift down!
1/4 mile: full interior and sound system.
Reaction: .6067 60 Ft: 2.3343 330Ft: 6.6654 1/8 ET: 10.2421 1/8 MPH: 68.70 1000' ET: 13.2334 1/4 ET: 15.9189 1/4 MPH: 86.35
PostPosted: Thu Feb 16, 2012 4:13 pm Up
if you're patient I found you're 206 will develop enough rattles to drown out the sound of the boot rattle Thumb Up
jayz206gti
PostPosted: Thu Feb 16, 2012 4:19 pm Up
I get a bit of a clunk when i go over speedbumps but i thought it may have been the parcel shelf. Could the boot latch be the cause then?
Upgraded from 138 to 180
craigdmjv
PostPosted: Thu Feb 16, 2012 6:33 pm Up
mine has trouble closing the little plastic thing has worn out on the latch Sad
L5_UKS
PostPosted: Thu Feb 16, 2012 7:24 pm Up
I've got a rattle on mine aswell, Its on my list of things to check ha, The joys of french eh!?
craigdmjv
PostPosted: Thu Feb 16, 2012 8:08 pm Up
Clios are worse I should know iv had 3 of them and then the 206 one of the most reliable cars I have ever owned tbh and mg metro turbos are quite reliable and good build quality too had one of them until the roof channels rotted and you got a shower when you went round a sharp corner in the mornings Laughing
lottley93
PostPosted: Thu Feb 16, 2012 10:40 pm Up
This..
had this on both my 206's now causing this rattle as mentioned, wrap insulation tape around it! Very Happy
craigdmjv
PostPosted: Fri Feb 17, 2012 3:37 am Up
Thata what I was thinking of doing my cars made of tape atm due to it holding the pass side mirror on Sad
rick-gti
PostPosted: Fri Feb 17, 2012 3:42 am Up
If you open the boot and look where the boot catch is fitted to the car undo the two torx bolts slightly and move the catch slightly towards you and then tighten it up. Worked on mine, and no of a few others it has worked for to.
clio 197sport owner
gpvecchi
PostPosted: Fri Feb 17, 2012 3:48 pm Up
Thanks, I'll try adjusting the latch (which doesn't seems worn)...
nellyhaggis
PostPosted: Fri Feb 17, 2012 5:35 pm Up
I moved the latch on mine. Rattle was a gonner!
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Sat Feb 18, 2012 4:01 am Up
Just rotate the plastic sleeve on the latch.
