Latest: airmastertapes
Overall: 17133
Online Now [302]:
Visitors: 302
Today: 39182
Total: 106703351
Forums › The Car › 206 Talk › mpg on throttle bodies
Go to page Previous  1, 2
usher
PostPosted: Fri Feb 17, 2012 1:06 pm Up
thanks for tha edward was waiting for your input
i wont be running cams as severe as yours, think i would stick to the re-profile i have now
reading the 205 forum it seams that if set up right on the RR it should be about the same as standard with gentle driving obviously
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Fri Feb 17, 2012 2:43 pm Up
Obviously more power means you'll drive it harder using more fuel but drive it sensibly and they are fine.
macj
PostPosted: Wed Feb 22, 2012 3:20 pm Up
The words throttle bodies and driving sensibly dont fit in the same sentence....... just the sound makes you put your foot down
spike_202
PostPosted: Fri Jun 22, 2012 3:05 pm Up
250miles to a full tank if your lucky may get near 280 on a v.long distance run, mines usually around 230ish as I do like to use the full extent of the rev range And mines been a dailey driver for the past 5years.
If your botherd about mpg and petrol prices engine tuning isent for you.
**spike's project**
TEAM:+200bhp
PostPosted: Fri Jun 22, 2012 3:34 pm Up
i know it is thirsty but never expect it to be that bad Shocked
usher
PostPosted: Fri Jun 22, 2012 3:35 pm Up
lol thanks for that i get just 300 with diving round town heavy footed atm with a few blasts
im sure i can manage with 250 but dont you have bigger injectors etc i will only have the tbs with my current mods, or would this be the same in fuel
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Fri Jun 22, 2012 3:36 pm Up
it won't run on std injectors Smile
it will be way too lean
and i think the kit come with injectors too
usher
PostPosted: Fri Jun 22, 2012 3:44 pm Up
kam racing dont list the injectors just that you get a fuel rail in the kit, mac also didnt mention injectors so assume you didnt need them
the mpg will seam bad to a deisel owner lol, my boss had a modeo st220 which on normal driving would only do 22mpg 28 on motorway being steady
project thread WIP
garage
FAQ
206 gti firedance
spike_202
PostPosted: Fri Jun 22, 2012 3:51 pm Up
He's only got v.mild cams seabook so standard injectors would be fine.... I think. I knoticed a drop in mpg straight away. as when I left my car with pug1off all I had dine to it was a k&n panel filter and a cat back Powerflow exhaust it came out with a race spec engine+a few extras i lived at the petrol station for the 1st cupple Of months as I was driving around every were then I started to find the balance when you 1st fill up you can drive it hard for the 1st half as it don't last v.long then just Eco drive for the last half lol, in the winter when it was freezing I was lucky to get 200 to a tank. On the way to fcs I did 150 round trip on half a tank but I was doing 60most of the way.
**spike's project**
TEAM:+200bhp
PostPosted: Fri Jun 22, 2012 4:07 pm Up
hmm....
i am surprise you can use standard injectors after ITB mod.
PostPosted: Fri Jun 22, 2012 4:08 pm Up
sure.
i just get 60mpg in last tank Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing
usher
PostPosted: Fri Jun 22, 2012 4:24 pm Up
im sometimes tempted to turn to the dark side because of this
project thread WIP
garage
FAQ
206 gti firedance
Page 2 of 2
