Online Now [40]:
Visitors: 39
Today: 52577
Total: 117302476
Forums › The Car › 206 Talk › HDI Engine cover
HDI Engine cover
mikec49
PostPosted: Sat Feb 18, 2012 12:41 pm Up
It was pointed out at my last service, that the engine cover mounts needed replacing, but the garage charge including labour was £46!
I looked online and unsurprisingly you can pick the bolts up for about £4 each, so thats like £30 labour, for what I can only see as a 5min job.
So why am I posting?
Well, I found 3 bolts in the engine, these were in line with the rubber mounts that were left in the cover,I removed them with a socket and replaced with the new ones I'd brought, so far so good, but the one to the right of the dipstick appears to have nowhere to screw into, has something fell off?
I'll attach pics on flikr, Engine Pics on Flikr
Ghosty
PostPosted: Sat Feb 18, 2012 1:31 pm Up
i did all 4 on my old car, i actually piced them up from the dealer for about 4.50 each, there positions for all 4 i cant fro the life of me remember where they all are.
but i do have a solution, take the 4th clip off, and the part under the cover so you have a hole, place the cover onto the engine (do not clip down) shine a light in the hole and see where the last one bolts to.
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
mikec49
PostPosted: Sat Feb 18, 2012 1:36 pm Up
i'll give that a try ghosty, (tomorrow in thr light) but i've got a feeling its looking to anchor on the silver part, on the pics, which is threadless, which is why I think maybe something has shook off, like a thread of some kind.
mikec49
PostPosted: Sun Feb 19, 2012 9:41 am Up
I checked, and as suspected, the only place to put the 4th cover damper, has no thread, are there any mechanics on these forums who could let me know what threaded bit is needed.
Ghosty
PostPosted: Mon Feb 20, 2012 7:15 am Up
i have a tap and die set here in swindon, that can be used to thread it again, but as you are not here it may be cheaper to go to a local motor factor or halfrauds and get a set yourself, with that you can create the thread required.
