Latest: flipflap
Overall: 17140
Online Now [138]:
Visitors: 138
Today: 30015
Total: 113937177
Forums › The Car › 206 Problems › 206 high revs, no acceleration and wobbles
Deanr86
PostPosted: Sun Feb 19, 2012 12:07 pm Up
i just bought a peugeot 206, its a 1.4 lx auto with the AL4 gearbox.
The problem with it is that the car takes an inordinate amount of time to accelerate. The car revs to over 3000 revs each time it changes gear.
If i put into sport mode if pretty much has to red line for each gear change.
It also takes an absolute age to change from second to first gear.
Also sometimes it will chug and just cut out.
Another problem is that while the car drives it wobbles.
If anyone has an ideas as to the cause of this would appreciate it.
PostPosted: Sun Feb 19, 2012 12:09 pm Up
Had it code read?
Gear changes sound normal.
Deanr86
PostPosted: Sun Feb 19, 2012 1:01 pm Up
not had a code read yet, just spent £250 quid on sorting out suspension and gearbox.
according to mechanic, oil in gearbox was not the right oil. Shocked
will get a code read on pay day
How much will a code read set me back?
PostPosted: Sun Feb 19, 2012 1:05 pm Up
Depends where you go.
Where you based?
Deanr86
PostPosted: Sun Feb 19, 2012 1:38 pm Up
Preston, Lancashire
should i go dealer or will any garage be able to do it?
PostPosted: Sun Feb 19, 2012 1:50 pm Up
Deanr86 wrote:
Preston, Lancashire
Lee can do these as he has Peugeot Planet diagnostic kit Wink
deanparkr
PostPosted: Sun Feb 19, 2012 7:04 pm Up
Sport mode does usually result in the car going almost to the red line before shifting in order to give "sporty" acceleration.
Do mean the other way round from first to second?
2002 1.4LX
Deanr86
PostPosted: Sun Feb 19, 2012 7:27 pm Up
no, i mean from second to first, when i slow the car down, it gears down fine until it has to gear from second to first then it sits at 2500 rpm until the car is below 10 mph were the revs then just drop off, and it finally engages first
deanparkr
PostPosted: Mon Feb 20, 2012 2:48 pm Up
Oh I see. Yeah there is something wrong there then. Whats the mileage on the car?
As far as I know the only real user serviceable part on the box is the gearbox oil. On the more complex and expensive side of things there's things like electrovalves. Although I dont really know much about that to advise i'm afraid.
2002 1.4LX
