Latest: ArtistKS
Overall: 17145
Online Now [67]:
Visitors: 66
Today: 36160
Total: 116093025
Forums › The Car › 206 Problems › Map sensor
Map sensor
SteveTDCi
PostPosted: Tue Feb 21, 2012 12:56 pm Up
What are the symptoms of a failing map sensor, the 206 still smells like its running a little rich. It could just be me thinking it smells though... It's a 1.4 8v none plex and I've changed the plugs to Bosch, pug air filter, the coolant temp sensor and the thermostat, all I can think of now is the map. I'm tempted to get a used one or cheap one from eBay, there is no miss fire and the plugs didn't look a bad colour
206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out
PostPosted: Tue Feb 21, 2012 1:00 pm Up
Try & get an exhaust emissions test done on it & see what the readings are, for example it could be lambda sensor on its way out but not gone out of spec enough to throw up a fault code.
Liam-HuTcH
East Area Rep - Liam-HuTcH
ive got a spare map sensor mate. and im only down the road?
Team: Smashed Up Firedance
Team: Black 206
SteveTDCi
PostPosted: Tue Feb 21, 2012 1:47 pm Up
Liam - thanks for the offer, I'll go for the lambda sensor first, well emissions and take it from there, mpg is 35mpg at the minute.
SteveTDCi
PostPosted: Tue Feb 21, 2012 1:58 pm Up
On the 99 model is there one or two sensors ? I could go and look but the wife has the car Smile I'm sure it's just a pre cat sensor .......
Liam-HuTcH
PostPosted: Tue Feb 21, 2012 2:16 pm Up
35mpg is good on a 99plate 1.4 8v iirc
Team: Black 206
PostPosted: Tue Feb 21, 2012 2:22 pm Up
My Euro 4 TU3 is running 31.4mpg average at moment, thats due to the operator Laughing
SteveTDCi
PostPosted: Tue Feb 21, 2012 2:31 pm Up
ah bugger, my old polo would crack 40mpg on the same trip Smile the Cupra (300bhp) averages 28mpg and the TT 29 ..... maybe its my imagination about the fuel Smile
PostPosted: Tue Feb 21, 2012 5:26 pm Up
This makes me happy. I was beginning to think it was time to start fault finding my daughters 1.4 8V. It runs sweet as a nut but only does 29mpg on short daily 5 mile runs.
Are these really this poor - she is not a fast driver.
Note: car fully serviced with new filters, plugs, oils etc. 1,000 miles ago and only 50,000 on the clock.
SteveTDCi
PostPosted: Tue Feb 21, 2012 5:30 pm Up
My daily run is 14 miles each way, 2 miles at 30mph, 8 at 70 mph then the remainder at 40/30 the polo was really good. That 35 was calculated with a blowing exhaust, open thermostat and old plugs and filter. Let's see if I can get it to 40 mpg
