Latest: Kifi69
Overall: 17183
Online Now [444]:
Visitors: 443
Today: 79940
Total: 144900197
Forums › The Car › 206 Problems › Hi temp when parked up
Steveo760
PostPosted: Tue Feb 21, 2012 1:47 am Up
Hay every 1. Drove to work this morning about a 38 miles and when I got here had a bit of time so sat in car for a bit. Temp when up from just below 90 to about 100 in 5 mins. Is this normal ? And is there and kits u can get to make them run cooler like u can get for the golf git 1.8 20vt's ? Thanks
Steve
gixxerkev
PostPosted: Tue Feb 21, 2012 2:31 am Up
Yes its normal as long as the fan kicked in and cooled it down again. Why would you wanna make the engine run cooler anyway, its designed to run at the temperatures indicated.
An Ex '03 1.4 GLX driver, German technology all the way now.
DRAPER
PostPosted: Tue Feb 21, 2012 3:17 am Up
mine does this too believe the fan kicks in at 100 if not start to panic lol Smile
when driving normally just sits between 80-90 when in traffic or standstill creeps up to 100 and fan kicks in and drops back to a steady 90
206 CC 2.0 GTI SE
HAPPY AS A PUG IN MUD
Lee wrote:
Buy a new car. The 1.9D is s**t anyway.
HA love it Smile
-Dave-
PostPosted: Tue Feb 21, 2012 4:02 am Up
Trade Rating: +36
As above it is perfectly fine. With petrol at the price it is though if I was sat anywhere for more than a minute engine would be off.
Ex 206 Owner.
Steveo760
PostPosted: Tue Feb 21, 2012 5:10 am Up
Ok thanks guys. So it starts to cool it down a bit soon that it's does read sum were its ment to help the engine live a little longer ??
Steve
PostPosted: Tue Feb 21, 2012 12:31 pm Up
there's NOTHING wrong with it & 90 deg C is bang on where it should be running.
If the car isnt moving that means there is no airflow through the radiator to cool it.
This means the engine temp will rise up till the cooling fan low speed is triggered which will then cool the radiator back down again & lower the engine temp.
That cycle will just repeat until you either start moving again or switch the engine off.
danlouiee
PostPosted: Tue Feb 21, 2012 12:38 pm Up
heaters full blast on hot if you want to bring it down slightly. Smile
PostPosted: Tue Feb 21, 2012 12:41 pm Up
Or stick the aircon on if you have it & its working, low speed fan will run Wink
PostPosted: Wed Feb 22, 2012 4:25 pm Up
Working 100% correct and does not need any attention or worry.
You are one of the lucky few as most posters on here do have an issue. It is then spent arguing over sensor or thermostat and if it is the sensor is it a blue one, green one or brown one. if it is the blue one then which one.
Don't worry and don't fit a cooler it is spot on.
sillyhilly
PostPosted: Wed Feb 22, 2012 4:33 pm Up
Hi
1 - interjection (used as an exclamation of greeting); hello!
Origin:1425–75; late Middle English hy, perhaps variant of hei (hey)
Hi Mikey Smile
Big_Rich180
PostPosted: Thu Feb 23, 2012 8:28 am Up
Laughing
