Online Now [300]:
Visitors: 300
Today: 100049
Total: 142482795
Forums › The Car › 206 Problems › High Pitched Engine
High Pitched Engine
Yossarian
PostPosted: Tue Feb 14, 2012 1:00 pm Up
Hi all I have noticed over the last week my engine seems to be making a higher pitched than usual noise when revved. This usually happens over 2000 revs. The thing is im not even 100% sure its not allways been there Ive only had the car six months. Is this something I should get checked out? eg is my engine about to explode? lol. I have an 04 plate 1.4 petrol, thanks in advance.
PostPosted: Tue Feb 14, 2012 1:14 pm Up
aux belt - tighten/replace
Yossarian
PostPosted: Tue Feb 14, 2012 1:30 pm Up
Thanks man, is this an expensive job? am I ok to keep driving it for now? It sounds a bit like a remote control car btw.
PostPosted: Tue Feb 14, 2012 1:42 pm Up
Nah cheap as chips
You can keep driving, but if it snaps then you'll have no electrics.
Davels
PostPosted: Tue Feb 14, 2012 1:54 pm Up
I have the same issue but with a chat chat chat noise coming from the same area as well. Pulley? if so any ideas on which one is most common to go? Going to have a go taking the belt off to have a proper look......no looking forward to it. Just shut my eyes and start hitting may be my best course.
Yossarian
PostPosted: Fri Feb 17, 2012 11:55 am Up
Took it to the garage today turns out it was the power steering pump. The Aux belt is looking a bit worse for wear any way so im getting it changed along with the cam belt. The radiator is leeking also due to corrosion so getting that replaced. Ive been quoted £385 for the new belts/pulleys pump and radiator.
PostPosted: Fri Feb 17, 2012 1:54 pm Up
I have a working PAS pump and radiator for a lot cheaper than that if you are interested
Yossarian
PostPosted: Fri Feb 17, 2012 5:24 pm Up
Thanks man but I allready ordered the parts, price includes labour too. Ill ask you first when I need a part in the future lol.
Yossarian
PostPosted: Thu Feb 23, 2012 1:30 pm Up
Got the car back today and its still making the high pitched sound! Also the new cam belt seems really noisy. It now sounds like a tractor in low revs and a remote controll car in high. Cost me £430 I am not happy.
DS
Yossarian
PostPosted: Sat Feb 25, 2012 6:13 am Up
Took it back, the cam belt wasnt fitted correctly they sorted it and the high pitched noise was coming from an Aux belt pulley as well as the pas pump. All fixed now and sounds great.
Davels
PostPosted: Tue Feb 28, 2012 11:22 am Up
Turns out my noise was the PAS pump too. Got the belt, tensioner and pump changed for £200 all in which wasn't too bad, or it would have been had I not alreaady spent 400 smackers on tyres this month! yawn!
Nathaniel206
PostPosted: Tue Feb 28, 2012 11:53 am Up
£400 on tyres ???????????????????????????
Peugeot 206 1.4 Owner!
PostPosted: Tue Feb 28, 2012 11:58 am Up
Easily done if you buy decent rubber Wink
PostPosted: Tue Feb 28, 2012 12:04 pm Up
do not apply to 14" or 15" wheels Laughing
PostPosted: Tue Feb 28, 2012 12:10 pm Up
185 55 15 V Michelin Pilot Exalto PE2 where £93 each last time I bought some a few months back Wink
