Latest: tebas93089
Overall: 17179
Online Now [114]:
Visitors: 112
Bots: 2
Today: 43536
Total: 137815318
Forums › The Car › 206 Problems › clutch replacement?
clutch replacement?
PugGti180
PostPosted: Fri Feb 24, 2012 6:32 am Up
ok I'm about to drop another 180 engine in my car and wondering if I should change the clutch before I do so? Also anything else I should change before hand? Obviously I'll change the timing belt and waterpump.
Cheers
Steve180
PostPosted: Fri Feb 24, 2012 6:49 am Up
Are you using the gearbox from the engine your transplanting or from your own car? If its from your own car, I would change the clutch, input shaft bearing and check the condition of the clutch fork.
GTi 180's are known for clutch judder.
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
PugGti180
PostPosted: Fri Feb 24, 2012 7:14 am Up
Yeah gearbox from my own car. I'm getting a garage to do it for me so should I ask them to check the condition of these things before buying them? Also do you know if these items are expensive?
Cheers
2005 Peugeot 206 Gti 180, Silver, 38,000mls Wink
Steve180
PostPosted: Fri Feb 24, 2012 7:58 am Up
The guide bush is £20.00 ish from Peugeot, clutch fork will be aound £30.00.
PugGti180
PostPosted: Fri Feb 24, 2012 8:12 am Up
Right no worries. Cheers for all the advice. Car has been off the road for 6 months so will be a joy having it back. Smile
Steve180
PostPosted: Fri Feb 24, 2012 10:42 am Up
Good stuff, glad to hear another 180 will be back on the raod Very Happy
marrygold75
PostPosted: Fri Feb 24, 2012 1:33 pm Up
change it while its easy peasy,
have a nice day
