Latest: Kifi69
Overall: 17183
Online Now [420]:
Visitors: 419
Today: 151162
Total: 144610793
Forums › The Car › 206 Talk › Indicator lenses
Indicator lenses
Forum Index › 206 Talk
chambie1980
PostPosted: Fri Feb 24, 2012 11:47 am Up
Hi peeps, I'm back again with my silly questions Very Happy Can anyone tell me how to replace the wing indicator lenses as I've looked all over the Internet looking for answers but found nothing and don't really want to be popping them out via the outside if that is the wrong way about it and scratching the paint.
chambie1980
scottsgti
PostPosted: Fri Feb 24, 2012 11:55 am Up
pretty sure they do just pop off, just have to be careful doing so.
moonstone blue 206 gti 138, sp kit. completely standard
PostPosted: Fri Feb 24, 2012 11:57 am Up
You can't JUST replace the side indicator lenses only,you need to change all of it,and if you are worried about having a scratch while having them off,take the wheel liner off,and you will have a very easy access to them,and only will take a min. to replace them.
chambie1980
PostPosted: Fri Feb 24, 2012 11:58 am Up
Thanks pal. If in doubt, try it out
chambie1980
scottsgti
PostPosted: Fri Feb 24, 2012 12:00 pm Up
ah, well there you are, i thought it would just pop out like all my previous cars lol.
learn something new everyday.
chambie1980
PostPosted: Fri Feb 24, 2012 12:02 pm Up
Thanks timon2210 think taking the wheel liner out is a better option for me.... Patience isn't one of my strong points and will probably end up doing damage
chambie1980
chambie1980
PostPosted: Fri Feb 24, 2012 12:03 pm Up
Lol I'm totally clueless Scott which is why and advice is welcome
chambie1980
2Oh!6
PostPosted: Fri Feb 24, 2012 12:05 pm Up
I've always just slid a blunt knife behind to pop in the clip and it will pop out, done it several times with no scratches.
VTEC goes BWAAAAAAH! Wink
chambie1980
PostPosted: Fri Feb 24, 2012 12:09 pm Up
Are the clips side or top and bottom pal ?
chambie1980
-Dave-
PostPosted: Fri Feb 24, 2012 12:10 pm Up
Trade Rating: +36
Just open the doors and use a screwdriver to unclip them from the back.
Ex 206 Owner.
chambie1980
PostPosted: Fri Feb 24, 2012 12:23 pm Up
Just been and had a look. Think suicidal's option is the best but thanks for allnoptions guys
chambie1980
chambie1980
PostPosted: Fri Feb 24, 2012 12:24 pm Up
All options* rather
chambie1980
Matt
PostPosted: Fri Feb 24, 2012 1:14 pm Up
Trade Rating: +32
This^^^
Or you can get a small flat blade screw driver, put electrical tape over the end so it doesn't scratch & pop them out.
chambie1980
PostPosted: Fri Feb 24, 2012 2:01 pm Up
If I pop the side clip nearest ( from inside ) I'm guessing it will be free enough to pull the rest out ? Also if I decide the exterior option I'm guessing I havnt looked wrong and it's a side clip rather than top/bottom ?
chambie1980
mtempsch
PostPosted: Fri Feb 24, 2012 2:07 pm Up
Mine had only one clip and it was located rearwards, facing the door.
With the door open I used a bamboo flower stick (~3/8" diameter) to reach in and press on the clip, angling it so it was also putting a little pressure outwards on the whole assembly.
Silvermetallic 2004 206 RC
