Latest: Beduff1977
Overall: 17134
Online Now [484]:
Visitors: 483
Today: 68720
Total: 109239569
Forums › The Car › 206 Problems › 2.0 hdi sport brake problem
mark5
PostPosted: Thu Feb 23, 2012 12:13 pm Up
Hi any ideas of this problem. Since last week when braking at low speed or normal 40/50 mph. when pressing the pedal all is fine then it seems as the abs has kicked in for a split second ( it feels like the brakes let go then go back to normal) pads and disc are all ok. No abs light on any ideas welcomed thanks mark,
HELLO
PostPosted: Thu Feb 23, 2012 12:14 pm Up
Check both front drive shafts for a broken ABS toothed ring.
They like to crack & it doesnt always put the ABS warning light on Wink
mark5
PostPosted: Thu Feb 23, 2012 12:29 pm Up
Cheers will have a look,
HELLO
mark5
PostPosted: Fri Feb 24, 2012 11:18 am Up
Spot on that man. drivers side has got a big crack in it. thanks mark,,
HELLO
PostPosted: Fri Feb 24, 2012 11:23 am Up
Its a very common 206 problem Wink
Check this thread as there is a supplier link in there for replacement ABS rings.
www.206info.co.uk/Foru...42505.html
mark5
PostPosted: Tue Feb 28, 2012 12:21 pm Up
Hi does anyone have the front wheel bearing torque setting. thanks mark
HELLO
