Online Now [493]:
Visitors: 492
Today: 102074
Total: 144922275
Forums › The Car › 206 Problems › How much will it cost to Fix/Replace the ECU???
mcass123
PostPosted: Mon Feb 27, 2012 7:22 am Up
My 206 1.1 lost all power, the engine management light came on and then it cut out.
It wouldnt start again, I called the AA out and the guy said it was showing injectors 1 and 3 were faulty all so the crank sensor. He towed me to a garage and they tried fixing both problems but have had no luck, they got an Auto Electrician to take a look and now its looking like the ECU is dead.
I am still waiting on that being confirmed but they are 99% sure that is the problem.
Can anyboday tell me how much I am looking at to get it fixed?
Thank you
PostPosted: Tue Feb 28, 2012 6:23 am Up
See second hand ECUs on ebay.
138Andy
PostPosted: Tue Feb 28, 2012 4:40 pm Up
30-40quid on gumtree
PostPosted: Tue Feb 28, 2012 4:43 pm Up
I wouldnt guess, get it to Peugeot for a code read.
PostPosted: Tue Feb 28, 2012 4:48 pm Up
No idea as my crystal ball is broken & there are 11 different part numbers listed for the TU1 ecu that lives under your bonnet.
VIN number would narrow it down exactly OR at least a year of 206 OR is your 206 non plexed or multiplexed?
daza4
PostPosted: Sun Mar 04, 2012 5:35 am Up
You can always try ECU doctor - send your ecu away they charge £30 to test it then give you a quote to fix if required. - they are based in plymouth and offer a good service - used them myself.
google it for their number.
Daza 4 \r\nPSOOC group leader Wiltshire Group\r\n\r\n205 gti track car\r\n206 GT
