Latest: jackrox1992
Overall: 17186
Online Now [355]:
Visitors: 354
Today: 42807
Total: 148580017
Forums › The Car › 206 Talk › autolock
autolock
Forum Index › 206 Talk
karimali831
PostPosted: Tue Feb 28, 2012 8:36 pm Up
I am not overly fussed about this feature although I would like it turned on, perhaps this time I won't be having some stranger opening my door asking for change Laughing
I haven't known about this until I searched up and tried turning it on by holding lock button but does nothing, this means I have outdated BSI ? If this means I must go to Peugeot dealer for an expensive update then I have second thoughts, apart from this could anything else activate it that I am not doing? Did everyone go through BSI update then who has same reg ? Confused
But first does a GTI 180 2004 support this feature...?!
Thanks all Smile
206 GTI 180
-Dave-
PostPosted: Tue Feb 28, 2012 8:38 pm Up
Trade Rating: +36
Was the key in first position when you tried it?
Ex 206 Owner.
karimali831
PostPosted: Tue Feb 28, 2012 8:42 pm Up
yes.
206 GTI 180
Rob2859
Sounds stupid but is the ignition on when you hold the button down? you have to hold it down for quite a bit too. Can't remember what year the update was.
karimali831
PostPosted: Tue Feb 28, 2012 8:44 pm Up
Tried both positions, held it 5-10 seconds or so and nothing happened. Will try again later..
206 GTI 180
karimali831
PostPosted: Wed Feb 29, 2012 7:27 am Up
Still can't get it working.. Sad
BSI needs updating then?
206 GTI 180
PostPosted: Wed Feb 29, 2012 10:10 am Up
Yes.
May need a BSI software update & will most likely need the BSI configuration tweaking.
deebee
PostPosted: Wed Feb 29, 2012 10:49 am Up
sorry guys but there's a auto lock feature?
Breaking 2.0 hdi with ps and gti bits
PostPosted: Wed Feb 29, 2012 11:07 am Up
When the car gets to about 6 mph the doors will automatically lock.
Only certain spec's of multiplexed 206 can do this.
Tom206
PostPosted: Wed Feb 29, 2012 11:34 am Up
does a 2002 2.0 HDi multiplexed do this?
2002 2.0 HDi SP
www.facebook.com/tomwebb01
PostPosted: Wed Feb 29, 2012 12:25 pm Up
You need the combined hazard / lock button fitted on the dash & also the feature turned on in the BSI configuration set up to get it to work.
karimali831
PostPosted: Wed Feb 29, 2012 1:58 pm Up
MrBSI: where can I update my BSI? Is it not free?
206 GTI 180
PostPosted: Wed Feb 29, 2012 2:04 pm Up
Peugeot main dealer only.
Only done FOC if the car is still under the original 3 year manufacturers warranty OR if its a safety recall that requires a download.
karimali831
PostPosted: Wed Feb 29, 2012 2:08 pm Up
Ok thanks and how much roughly will they charge for this?
206 GTI 180
PostPosted: Wed Feb 29, 2012 2:11 pm Up
Either half hour or an hours labour depending on the actual dealer.
