Posted: Tue Feb 28, 2012 8:36 pm |
I am not overly fussed about this feature although I would like it turned on, perhaps this time I won't be having some stranger opening my door asking for change
I haven't known about this until I searched up and tried turning it on by holding lock button but does nothing, this means I have outdated BSI ? If this means I must go to Peugeot dealer for an expensive update then I have second thoughts, apart from this could anything else activate it that I am not doing? Did everyone go through BSI update then who has same reg ?
But first does a GTI 180 2004 support this feature...?!
Thanks all
Posted: Tue Feb 28, 2012 8:38 pm |
Trade Rating: +36
Was the key in first position when you tried it?
Posted: Tue Feb 28, 2012 8:42 pm |
| Suicidalsoldi3r wrote: |
| Was the key in first position when you tried it? |
yes.
Sounds stupid but is the ignition on when you hold the button down? you have to hold it down for quite a bit too. Can't remember what year the update was.
Posted: Tue Feb 28, 2012 8:44 pm |
| Rob2859 wrote: |
| Sounds stupid but is the ignition on when you hold the button down? you have to hold it down for quite a bit too. Can't remember what year the update was. |
Tried both positions, held it 5-10 seconds or so and nothing happened. Will try again later..
Posted: Wed Feb 29, 2012 7:27 am |
Still can't get it working..
BSI needs updating then?
Posted: Wed Feb 29, 2012 10:10 am |
| karimali831 wrote: |
Yes.
May need a BSI software update & will most likely need the BSI configuration tweaking.
Posted: Wed Feb 29, 2012 10:49 am |
sorry guys but there's a auto lock feature?
| Breaking 2.0 hdi with ps and gti bits | |
Posted: Wed Feb 29, 2012 11:07 am |
| deebee wrote: |
| sorry guys but there's a auto lock feature? |
When the car gets to about 6 mph the doors will automatically lock.
Only certain spec's of multiplexed 206 can do this.
Posted: Wed Feb 29, 2012 11:34 am |
does a 2002 2.0 HDi multiplexed do this?
Posted: Wed Feb 29, 2012 12:25 pm |
| Tom206 wrote: |
| does a 2002 2.0 HDi multiplexed do this? |
You need the combined hazard / lock button fitted on the dash & also the feature turned on in the BSI configuration set up to get it to work.
Posted: Wed Feb 29, 2012 1:58 pm |
MrBSI: where can I update my BSI? Is it not free?
Posted: Wed Feb 29, 2012 2:04 pm |
| MrBSI: where can I update my BSI? Is it not free? |
Peugeot main dealer only.
Only done FOC if the car is still under the original 3 year manufacturers warranty OR if its a safety recall that requires a download.
Posted: Wed Feb 29, 2012 2:08 pm |
| MrBSI wrote: |
Only done FOC if the car is still under the original 3 year manufacturers warranty OR if its a safety recall that requires a download. |
Ok thanks and how much roughly will they charge for this?
Posted: Wed Feb 29, 2012 2:11 pm |
| MrBSI wrote: |
Ok thanks and how much roughly will they charge for this? |
Either half hour or an hours labour depending on the actual dealer.
