Posted: Wed Feb 29, 2012 1:27 pm |
Hi,
I plugged in my fault code reader today and it came back with P1471 P0122 and P2408.
The codes were erased but came back again this afternoon.
Does anyone know what these codes are?
And does anyone know how to fix them?
Any help will be greatly received as Im new to the fault code game.
Cheers.
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Wed Feb 29, 2012 1:33 pm |
P1471 - Electrodrive Fan 1 Operational failure (Driver side)
P0122 - Throttle/Pedal Position Sensor/Switch "A" Circuit Low
P2408 - Fuel Cap Sensor/Switch Circuit
Posted: Wed Feb 29, 2012 1:43 pm |
Take it the Diesel Filter Blocked fault has come up?
Posted: Wed Feb 29, 2012 1:58 pm |
Abzynthe wrote: |
P2408 - Fuel Cap Sensor/Switch Circuit |
Cheers for that.
Now any idea how I fix them?
Posted: Wed Feb 29, 2012 1:59 pm |
Lee wrote: |
Take it the Diesel Filter Blocked fault has come up?  |
Hi Lee,
Its come up with ''anti pollution fault''.
Posted: Wed Feb 29, 2012 2:16 pm |
^^^^ will come up with the FAP fault soon.
Need the two new magnet type sensors from Pug, about £65 last I checked.
P0122 - test the TPS
P1471 - cooling/ac fan
PS...did you ask on here because you didn't get a reply on Peugeot Central?
Posted: Wed Feb 29, 2012 2:24 pm |
Regarding P2408 - Ive read on pug central it might be the wiring. What are the magnets that you mention?
P0122 - any idea how I would go about testing the TPS?
P1471 - my fan has been running at random times and runs for a bout 5 mins when I switch the car off on occation. I this just a simple case of replacing the fan switch in the rad?
Ps. ye, pug central is a bit slow on replies.
Posted: Wed Feb 29, 2012 2:27 pm |
nellyhaggis wrote: |
Sounds like its trying to do a regen
Posted: Wed Feb 29, 2012 2:33 pm |
On top of all this it also looses mpg at times, dropping from 55-60 mpg to 28-34 mpg doing the same speed and type of driving.
