Posted: Sat Mar 03, 2012 4:01 pm |
A piller is the front one.
Its the curved piller between edge of windscreen & front door, if its got an alarm then there will be a sensor at the top of each A piller.
Posted: Sat Mar 03, 2012 4:38 pm |
Whereabouts in leicester are you? If its not too far i can have a look at the brakes etc for you and give you an informed opinion on what needs doing.
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Sat Mar 03, 2012 4:40 pm |
Thanks BSI, I will check in the morning.
Hi Matt, near Victoria Park
Posted: Sat Mar 03, 2012 4:54 pm |
Brakes and pads shouldn't cost no more than 50-60quid and i got myself Brembo disc and Ferodo Premier pad if you need new set,as for front wing panel they may be easy to take apart but takes time if there are hidden bolts that would require lifting car up to remove from bottom.
Posted: Sat Mar 03, 2012 7:12 pm |
| MrBSI wrote: |
| Yours is multiplexed - 1 press on the remote lock button should arm the alarm & if you have them fitted set the deadlocks. |
1 press locks doors and sets alarm
2nd press within a couple of seconds activates deadlocks
If you don't 2nd press it in time it just flashes the indicators about a billion times and puts the interior light on (something to do with helping you find your car at night )
Well that's how my CC works,it's an 03 multiplex
| Yes I own a CC and I'm neither gay or a hairdresser!! | |
Posted: Sun Mar 04, 2012 3:20 am |
| fatboyslim wrote: |
| MrBSI wrote: |
Well that's how my CC works,it's an 03 multiplex |
WRONG!
On a multiplex 206 with deadlocks its the FIRST press that sets alarm & deadlocks.
If the lock button is pressed a 2nd time within 5 seconds it then removes the deadlocks & just leaves it normally locked, also depending on which BSI software version your running it can disarm the alarm system as well.
Go sit in your CC & press the remote fob lock button twice, then pull the interior door handle & see what happens
Posted: Sun Mar 04, 2012 3:50 am |
brake pad and disc should last for a good 4-5 years unless you drive for living or you doing crazy mileage per year
Posted: Sun Mar 04, 2012 3:53 am |
Oh bugger
I was told wrong then
So all this time I've been un-deadlocking my car
The alarms been set though as the lil red led flashes still
Posted: Sun Mar 04, 2012 3:54 am |
| Seabook wrote: |
| brake pad and disc should last for a good 4-5 years unless you drive for living or you doing crazy mileage per year |
Or you buy cheapos
Or you're a heavy braker
4-5 years from a set of pads/discs is something I've never managed
(still only had the Pug since July '11)
I had a Cavalier SRi130 and that used to eat pads, I only managed a year from a set of Mintex and they used to be guaranteed for a year
But I know it's the way I drive as I brake hard and late
Posted: Mon Mar 05, 2012 11:28 am |
| MrBSI wrote: |
| fatboyslim wrote: |
| MrBSI wrote: |
WRONG!
Go sit in your CC & press the remote fob lock button twice, then pull the interior door handle & see what happens  |
This might just well explain why some $%$£ managed to break into mine quite so easily. Thanks for pointing this out, good for future reference!
