Posted: Mon Mar 05, 2012 6:08 am |
Are the gti 137/138 and 180 front anti-roll bars the same size or different.
Also what size are they.
Cheers
Posted: Mon Mar 05, 2012 10:53 am |
180 gti run 21mm F-ARB
gti is 20mm
Posted: Mon Mar 05, 2012 1:10 pm |
I'm sure I once read earlier GTi's might have had a different front ARB but most will be 20mm as mentioned above.
Posted: Mon Mar 05, 2012 1:26 pm |
i think the later gti's have 22mm arb.
Posted: Mon Mar 05, 2012 1:33 pm |
GTi = 20 or 21 (after October 3, 2005)
GTi 180 = 21
SW with 138 engine = 22
Posted: Mon Mar 05, 2012 3:06 pm |
22mm SW GTI bars maybe cheap upgrade for gti180. Hmm.
| 2005 206 RC RED
Lot's of CNC machined customs pars.  | |
Posted: Mon Mar 05, 2012 3:08 pm |
5081 F9 @ £92.23
Posted: Tue Mar 06, 2012 2:13 am |
Not so sure why anybody would want a thicker front ARB.
Posted: Tue Mar 06, 2012 3:08 am |
Edward wrote: |
Not so sure why anybody would want a thicker front ARB. |
Better steering on track. And I agree. On the non smooth surface like bumpy roads thicker front ARB cause understeer. But on highways and track its really good.
| 2005 206 RC RED
Posted: Tue Mar 06, 2012 4:48 am |
The one i have just sold is a 22mm from a 2000 gti
Posted: Tue Mar 06, 2012 6:09 am |
Schumi wrote: |
Edward wrote: |
Better steering on track. And I agree. On the non smooth surface like bumpy roads thicker front ARB cause understeer. But on highways and track its really good. |
Will cause more understeer on all roads...
Posted: Tue Mar 06, 2012 12:37 pm |
Schumi wrote: |
Edward wrote: |
not too sure; and is also depends on what spring rate you got at the front.
i prefer the handling without front ARB, perfectly fine on smooth tarmac.
