Latest: airmastertapes
Overall: 17133
Online Now [1263]:
Visitors: 1262
Today: 10195
Total: 106870812
Forums › The Car › 206 Talk › 206 Gti front anti-roll bar size
rick-gti
PostPosted: Mon Mar 05, 2012 6:08 am Up
Are the gti 137/138 and 180 front anti-roll bars the same size or different.
Also what size are they.
Cheers
clio 197sport owner
PostPosted: Mon Mar 05, 2012 10:53 am Up
180 gti run 21mm F-ARB
gti is 20mm
PostPosted: Mon Mar 05, 2012 1:10 pm Up
I'm sure I once read earlier GTi's might have had a different front ARB but most will be 20mm as mentioned above.
simpsonrc
PostPosted: Mon Mar 05, 2012 1:26 pm Up
i think the later gti's have 22mm arb. Confused
PostPosted: Mon Mar 05, 2012 1:33 pm Up
GTi = 20 or 21 (after October 3, 2005)
GTi 180 = 21
SW with 138 engine = 22
Schumi
PostPosted: Mon Mar 05, 2012 3:06 pm Up
22mm SW GTI bars maybe cheap upgrade for gti180. Hmm.
2005 206 RC RED
PostPosted: Mon Mar 05, 2012 3:08 pm Up
5081 F9 @ £92.23
PostPosted: Tue Mar 06, 2012 2:13 am Up
Not so sure why anybody would want a thicker front ARB.
Schumi
PostPosted: Tue Mar 06, 2012 3:08 am Up
Better steering on track. And I agree. On the non smooth surface like bumpy roads thicker front ARB cause understeer. But on highways and track its really good.
2005 206 RC RED
rick-gti
PostPosted: Tue Mar 06, 2012 4:48 am Up
The one i have just sold is a 22mm from a 2000 gti
clio 197sport owner
PostPosted: Tue Mar 06, 2012 6:09 am Up
Will cause more understeer on all roads...
PostPosted: Tue Mar 06, 2012 12:37 pm Up
not too sure; and is also depends on what spring rate you got at the front.
i prefer the handling without front ARB, perfectly fine on smooth tarmac.
