Online Now [118]:
Visitors: 117
Today: 40948
Total: 138609335
Forums › The Car › 206 Problems › GTi gearbox issues...
PostPosted: Mon Mar 05, 2012 5:55 pm Up
My GTi gearbox seems to be having it's time of the month. At low speeds/revs it goes into gear ok, not quite as smooth as it should be but goes in. At higher speeds it either refuses to go in or takes a bit of force sometimes followed by some crunching noises.
I will be checking/changing the oil tommorow, however something tells me it wont be quite that simple. There arent any other strange sounds coming from the box.
Anybody else got any other thoughts what it could be?
PostPosted: Mon Mar 05, 2012 6:02 pm Up
synchro....
did you check the gearbox mount and rod?
PostPosted: Mon Mar 05, 2012 6:04 pm Up
Havent looked under the bonnet yet.
Why would the gearbox mount have anything to do with it? And what rod?
PostPosted: Mon Mar 05, 2012 6:08 pm Up
try to drive a 206 with broken gearbox mount then you will know.
higher rev=more vibration=worse.
linkage rod
PostPosted: Mon Mar 05, 2012 6:26 pm Up
oh right will check it tommorow then. Will check the linkage but i can't see it being that as it had them all changed when the gearbox was changed a few months ago.
PostPosted: Mon Mar 05, 2012 6:37 pm Up
did it shift well if you match the rev in N first?
PostPosted: Mon Mar 05, 2012 6:43 pm Up
Havent tried doing that. Once its over around 3.5/4k revs it struggles. 2nd gear particularly. When you go really high up the rev range, you put the clutch in and try to engage the next gear and it wont go in untill the revs have come down a bit.
craigdmjv
PostPosted: Mon Mar 05, 2012 6:58 pm Up
www.ebay.co.uk/itm/Peu..._500wt_939
PostPosted: Mon Mar 05, 2012 7:02 pm Up
it won't go in go you mean it won't even go into N or just won't go into next gear?
PostPosted: Mon Mar 05, 2012 7:11 pm Up
It Goes into N fine, its just not going into the next gear properly, even on the downchanges. 2nd seems to be worst however.
PostPosted: Mon Mar 05, 2012 7:19 pm Up
i would think is worn synchro then.
sadly it will be hard to tell unless you strip the box.....
PostPosted: Mon Mar 05, 2012 7:27 pm Up
Oh dear :/ I will try an oil change first then if that doesnt help, looks like time to get rid of it.
PostPosted: Mon Mar 05, 2012 7:39 pm Up
synchro is cheap....
PostPosted: Mon Mar 05, 2012 8:05 pm Up
How cheap? How big a job is it to change?
rick-gti
PostPosted: Tue Mar 06, 2012 3:01 am Up
have a gearbox if you need one, £40 let me no
clio 197sport owner
